Sachs clutch for aasco lwfw
Does anyone have the part numbers for me to double check...does the job just require the 996 clutch parts. (Sachs sport sprung)...
reason I ask is the same job on a 986S requires use of 997S clutch cover...but have found no reference to that for the 996 3.4.
thanks
thanks
Edit:
Looks like you can choose just about any of these implying you mean pressure plate and not cover:
http://www.pelicanparts.com/catalog/...TCLUTC_pg4.htm
Not sure this helps but for my setup here's what I did:
Aasco LWFW
Clutchmasters FX350
New pilot bearing
New flywheel bolts
Make sure the setup gets it balanced checked before installing if you can.
Aasco LWFW
Clutchmasters FX350
New pilot bearing
New flywheel bolts
