Immobilizer Fault Code 39, P1571
I've resolved my problem with this fault code but I'm just posting this in case someone else runs into the same fault code given how long it took me to figure this one out and how little information there is out there on this code. I have a 2000 996 Cabriolet that got water under the driver's seat due to a blocked drain (I really wish I had read about this problem here before it happened to me!). The drain at the bottom of the tray behind the driver's side rear seat speaker was completely blocked with bits of plastic and leaves. It had overflowed and flooded under the driver's seat. This killed the immobilizer which I had to send out to get replaced. However, after replacing the immobilizer I kept getting Immobilizer Fault Code 39 (P1571) from my Durametric. The symptoms were that when you tried to start the car, the dash would light up properly but the starter would not crank.
The reason that the car was outside in the rain was that I also had my ignition switch fail. Between the time that the switch failed and when I was able to replace it, there was a big rain that flooded the car. Unfortunately, this complicated the problem since my replacement of the ignition switch resulted in my moving, and potentially causing a wiring problem with, the ignition switch and immobilizer signal converter which sits on top of the ignition cylinder which is part of the immobilizer system!
This code seems to indicate that the "OK to start" signal is not getting from the immobilizer to the ECU. I spend days checking out everything from the key fob, ignition cylinder (which senses the key fob), immobilizer signal converter, immobilizer, ECU and all wiring in between with no luck. I finally decided to carefully clean each contact of the wiring harness that connects to the immobilizer under the driver's seat with a small pick and that was the problem! The contacts looked clean but they were not. As soon as I cleaned the contacts with the pick, the car started right up!
Hope this helps someone who gets the same code.
Have the same exact problem!!!
The immobilizer is under the driver's seat. You will need an exterior torx bit size E12 to remove it. There are four bolts holding the front and rear of the seat tracks to the floor. Remove the bolts and tilt the seat over being careful not to strain the power seat cables. There is a single plastic bolt holding the immobilizer to the floor. It sits in the lowest point of the floor where all the water collects if you have a leak - great place for a critical, expensive electronic module! You can try to dry it out yourself but I wasn't so lucky. I ended up sending mine out to Sean at ECU Doctors for repair. It was $675.
I would check the wiring first to make sure it's just not something loose before spending any money. It's up to you if you want to go the ebay route but I would make sure you buy from someone who takes returns in case it doesn't work out.
I've resolved my problem with this fault code but I'm just posting this in case someone else runs into the same fault code given how long it took me to figure this one out and how little information there is out there on this code. I have a 2000 996 Cabriolet that got water under the driver's seat due to a blocked drain (I really wish I had read about this problem here before it happened to me!). The drain at the bottom of the tray behind the driver's sie rear seat speaker was completely blocked with bits of plastic and leaves. It had overflowed and flooded under the driver's seat. This killed the immobilizer which I had to send out to get replaced. However, after replacing the immobilizer I kept getting Immobilizer Fault Code 39 (P1571) from my Durametric. The symptoms were that when you tried to start the car, the dash would light up properly but the starter would not crank.
Former Vendor
A lot of good ideas here on this thread.
"Clean, dry and tight" connections is one of those "electronic basics" that are a perfect example in this case of what can go wrong when the connections are otherwise.
We made a video on how to remove the Immobilizer CLU from your Porsche (Instructions starts 20 seconds into the video.)
Now when it comes to buying a "used ecu set" from ebay or anywhere else that is always an option that we consider a very last resort because of complications that we discuss here:
I hope that these 2 videos give you helpful info on this topic.
CharlesLS (08-15-2023)
Thanks for posting this.
We we just had a similar problem: drain hole got plugged and water collected under the drivers seat ruining the immobilizer unit.
Its been replaced but now we need to get the key fobs reprogrammed and we can't locate the immobilizer code.
Ugh.
Ugh.
ECU Doctor. Thanks for posting the interesting videos. I have 997.1 Immobilizer, Key and ignition switch but sold my ECU. Is there value with the remaining parts for someone or should I just toss them?
Former Vendor
Former Vendor
I'm sure we can salvage parts from those units to make something!
PM me if you want.
