996 Forum 1999-2005
Window not coming down when opening the door
Old 03-20-2017, 11:33 PM
wyovino
wyovino's Avatar
Originally Posted by antrn99
Thank you all. Just FYI it was the regulator that was bad. I had shop install. I think he robbed me. Paid 200.00 (from Porsche) for part and 360.00 to install. That was 4 hours of labor at 90.00 per hour. I think it should have been like 2.5 hrs but oh well at least I can open and close my window and door.
If you have money to burn, that's fine, otherwise you can save a ton by working on the car yourself. Many things that might seem daunting are in fact easy. Other things that might seem easy are far from it. Search the DIY's to decide.
Old 03-24-2017, 09:31 AM
marktrav
marktrav's Avatar
I've got this exact problem on my '02 996. Driver's side window goes up and down fully and normally via the window control, but the slight tick down on opening the door and closing the door is not working.
To be clear, if I open the door from the inside or outside does not matter, the slight tick down does not happen. However, if I gently push the window down, then close the door, the slight tick up DOES happen. So, whatever mechanism causes the slight tick down from inside or outside seems to be the culprit.
Old 03-24-2017, 10:03 AM
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
Ok,
Just an FYI window started to grind on the way down. replacing regulator. I will update when I get it back
FYI... Part was 275.00 labor.. 250.00
Anthony
They're jacking you up on the part price...They're paying $125. The labor is close - obviously much cheaper (i.e. $0) if you do it yourself, but that's your call - it's a 1 hr. job, but the devil is in the details - if you trust the mechanic all's good.
Old 03-24-2017, 11:26 AM
Rick_K
Rick_K's Avatar
I had mine replaced recently.....just about the same cost. I'm Learning to be a little more of an adventurist and tackle some of these little maintenance projects.
Quick Reply: Window not coming down when opening the door
