Replaced fuel vent valve - now unable to fill gas tank
#31
Brilliant.Thanks Ahsai.
For more , Search for "Smart Glow LED indicating fuses"
Here is the detail for visual learners(like me)
useful tool for a wring harness defect
#32
I broke down and brought the car to an indy shop. In their initial diagnosis I learned the part I replaced was defective, but they are still working on tracing the short. I'll report back when they find it.
That tone tool idea is great. I have one of those that I used for telecom work.. good to see how I can re-use the tool for automotive wiring checks in the future.
#33
Update: I misunderstood the defective part. The pic belows shows the 2 parts being replaced.
The pic below this shows where my reed switch was part of the problem. For anyone coming upon this thread do yourself a favor and INSPECT this when swapping out the 996-201-143-01 Fuel Line Vent Valve.
The Fuel Tank Vent Valve they were able to test as being defective. Downside is since I have a Carerra 4 the front end has to come down for them to get access to the gas tank to replace the part
Last edited by djbooya; 04-14-2017 at 05:59 PM. Reason: added link to the part I replaced
#34
Glad to read of a successful diagnosis. If you are pleased with the work by your Indie, you might publish their contact info here to help others looking for help in your area?
#35
https://www.yelp.com/biz/fremont-for...repair-fremont
444 Mowry Ave
Fremont, CA 94536
(510) 344-2876
EuroCarTech.com
They don't specialize in just PCars, but every time I've been there I've seen no less than 4 that were in for service..
They do have a lot of experience with them though.
I was turned on to them by a friend.
#38
Glad it worked out finally...
Go for a nice long drive!
#40
The defective part photo looks like it had a short and overheated badly. In theory the E6 fuse should have blown long before the part softened and bloated with heat ?
#41
That's what the shop said too.. I'm not sure what happened...I remember looking at fuse E6 originally and it wasn't blown (way before I changed the original valve). I'm wondering if I had a defective fuse somehow...once it blew then it consistently blew though.
#42
#43
He had to take down the front axle. I think he said it was required for C4s.
#45
