996 Forum 1999-2005
Try and smack this tophat bolt out or not?
Old 08-08-2016, 02:30 PM
jj1
jj1's Avatar
If it snapped that easy I wouldn't consider anything other than replacing the part.
Old 08-08-2016, 03:58 PM
Cuda911
Cuda911's Avatar
I'm going to eventually upgrade the suspension, but can't do that until the end of the season, as it will move me to a different car classification category. That's why I want a band-aid solution for now, if it will work.
Youri, I don't think there's any way to get vice grips, etc. on it from the bottom.
Old 08-08-2016, 04:40 PM
Schnell Gelb
Schnell Gelb's Avatar
Cuda,
The conventional (but bad imho) technique would be
1. grind the top of the broken bolt flat
2. Center punch it
3. Cobalt drill bit (undersize)with cooling oil
4. Many applications of Kroil to the remainder to soak the splines
5. Small sharp punch to delicately(??) collapse the remains inward and down through the hole.
In the time this tales you could have removed the strut and pressed out the broken bolt ?
Old 08-08-2016, 04:54 PM
Youri Ko
Youri Ko's Avatar
Cuda, I did not mean wise grips, IIRC , the bolts are pressed into the top plate.
I was refering to disconnecting the shock/spring from the bottom and wiggling the whole assembly.
Otherwise, few hits of zip-gun (whatever it's called) on that bolt, from top straight down will dislodge it very quickly.
This
Old 08-08-2016, 04:57 PM
5CHN3LL
5CHN3LL's Avatar
^ Yup. Air hammer that bish. Don't whack it with a sledge - let the compressor do the work.
Old 08-08-2016, 05:00 PM
Slakker
Slakker's Avatar
Plasma cutter should do the trick.
Old 08-08-2016, 05:17 PM
DTMiller
DTMiller's Avatar
Old 08-08-2016, 05:27 PM
5CHN3LL
5CHN3LL's Avatar
Old 08-08-2016, 05:40 PM
Cuda911
Cuda911's Avatar
Old 08-08-2016, 06:33 PM
ryanjboutin
ryanjboutin's Avatar
Hit it with a torch for a bit, take a ratchet extension and hammer the extension on the top of the bolt until loose?
But, I'd probably take it off completely and work it out on a bench. lol
Old 08-08-2016, 06:42 PM
5CHN3LL
5CHN3LL's Avatar
I think the goal is an in-situ repair. If he's going to go through all the trouble to remove it, it's moot.
Old 08-08-2016, 06:44 PM
ryanjboutin
ATF/acetone and time then, I suppose.
Old 08-08-2016, 07:01 PM
Cuda911
Cuda911's Avatar
Indeed.
Old 08-08-2016, 08:09 PM
dgi 07
dgi 07's Avatar
Is it out yet? Air hammer, pointed tip, and 10 seconds.
put the wheel back on, and put some weight on the top plate so it doesnt move, then hit it with the air hammer. Line up a new one and pull it home with a throw away nut. Install new nut and torque to spec.
Old 08-08-2016, 08:17 PM
Cuda911
Cuda911's Avatar
I won't have time to mess with it until the weekend. I don't have any air tools though. I have a manual impact screwdriver, so maybe that will work.
Quick Reply: Try and smack this tophat bolt out or not?
