2004 C2 Frunk
2004 C2 Frunk
Should my frunk rattle at all? When it's latched I can press lightly on either side of the emblem and it seems to not be fully latched. I started to adjust the rubber bumpers maybe 1 turn out but now have the frunk refusing to latch properly and accompanied by the dashboard warning/beep that it has popped open. Searched but didn't have a lot of success and hope that someone can nudge/shove me in the right direction. Thanks, Ralph
Received 1,091 Likes
Try this: screw the rubber bumpers all the way in so they make no contact. Close trunk lid and make sure it is latching properly. The trunk lid should be perfectly aligned with the top of the bumper. If not, then you may have to adjust the latch a little bit. It does have some adjustment room. Once the hood/latch is correctly aligned, put a little vaseline on the end of the rubber bumpers and start adjusting them outwards until you just make some contact with the body, as told by vaseline leaving a spot on the body, then adjust them about one-half turn outward more. May take several attempts to get it right. That should do it.
