Purchase decision 3.4 vs 3.6
#33
Personally I like the 3.6 bigger engine, different headlights, updated cluster and a glove box! The glove box seals the deal haha. Both great looking cars
#35
Meh, mine has my service wallet in it an empty savage garden cd case and torch. I should ditch the torch and the cd case to save weight. It is super handy for that extra kg though!
#36
The other big issue is that you can run into IMS bearing replacements that occurred AFTER the original failed. If the original bearing fails, the engine is disqualified from the IMS retrofit and the IMS solution due to the metal debris that gets run through the whole engine with the oil, and will subsequently destroy any new bearing that is installed.
#38
Definitely. Those looking for such a low-mileage example do so to find the most original car possible; they want to be the ones to make sure that the work is done perfectly, with exactly the parts they want, or believe that the lower mileage will make the car last longer.
#39
If I were buying a 996 I would take a factory bearing car over an upgraded one unless the upgrade was done by one of the certified installers and that could be verified. Either way I would be budgeting to have it replaced just the same (unless a certified installer confirmed they did it and all was good).
As far as Woodman's specific question, had I known ours was a dual before I had it opened, I would have simply done the clutch and not thought twice. I wouldn't have even had the outer seal pulled. Once we were in there that far, however, it seems silly not to just get it done. Hopefully the dual row Solution will be available by the time we need our next clutch.
#42
Car has 90,000 Kms on it and the below is all new work
REPLACED IMS BERING
REAR MAIN SEAL
NEW WATER PUMP
NEW CATALYTIC CONVERTERS
NEW CLUTCH DISK/ PRESS PLATE
RELEASE BEARING/ CLUTCH FORK
TUNEUP/ PLUGS
TRANSMISSION SERVICE
ALL LEAKS FIXED GASKETS AND SEALS
SOME OF THE EXTRAS INCLUDE
V2 VORTECH ENGINEERING SUPERCHARGER 470HP ($14000.00)
KW SUSPENSION V3 COILOVERS FRONT AND REAR SHOCKS
HIGH PERFORMANCEADJUSTABLE COMPRESSION AND REBOUND ($6500.00)
Anyone have experience with a supercharger kit on a Porsche? Worries me a bit.
#43
Speaking of fish in the sea, a 2002 C2 was just reduced that I've kep my eye on.
REPLACED IMS BERING
REAR MAIN SEAL
NEW WATER PUMP
TUNEUP/ PLUGS
REPLACED IMS BERING
REAR MAIN SEAL
NEW WATER PUMP
TUNEUP/ PLUGS
#44
REPLACED IMS BERING
REAR MAIN SEAL
NEW WATER PUMP
TUNEUP/ PLUGS
REPLACED IMS BERING
REAR MAIN SEAL
NEW WATER PUMP
TUNEUP/ PLUGS
