Dension 500 gateway + bluetooth adapter question
#31
Thanks 318, that's the same kind of set up ill be using although I'll be using the bta1500 so hopefully it's good enough to be mounted in the frunk and Pickup my phone in the cabin. If not ill run the cable in.
As for the wiring there are two grommets you can go though the first - frunk into bulkhead area and then another into the cabin (looks like you found that one though).
I started a thread here that shows the frunk to bulkhead area gromet:
https://rennlist.com/forums/996-forum/998969-part-number-please-bulkhead-rubber-grommet.html
#32
Hah, I'll take a look behind the whole brake reservoir setup. I thought I had looked everywhere, obviously not thorough enough! Need to wash the car as it was either too cold or wet or both at the moment :-(
#33
Actually on our RHD cars it's near the Abs unit on the other side
#35
Guessing your 996 is a C4 or C4S from the look of the frunk?
I'm also going to poke my ctek charger cables through that grommet so I don't have to remove the battery cover to charge it as mentioned in that thread.
#37
@numbah, for me, it's not an issue as I just put on Spotify's "Latest Hits" tracks and leave it at that. I will also get too busy driving to want to change songs. Volume obviously is controllable from your head-unit. I don't utilise iPod as I only use Spotify, as per the above.
#41
#45
