996 Forum 1999-2005
I bought KK's car(long story...)
Old 04-14-2016, 04:27 PM
  #61
Atrox
Atrox's Avatar
The fact that PO posted that current owners car failed is low down, insulting, and frankly inexcusable. pandering is all this is.
Atrox is offline
Old 04-14-2016, 04:53 PM
  #62
DTMiller
DTMiller's Avatar
Originally Posted by extanker
good call paul. many of the re-pliers in a perverse are glad that the op,s engine failed.....it gives them a chance to key board fight KK. i would not buy from half these hippocritter po cheerleaders .as for the [ha ha] legal "advice" ninja pleeezzzz......dude could not fix a dog walking case from their mommies basement
I litigated one of the largest civil cases in the history of the United States. I think there is a case.
DTMiller is offline
Old 04-14-2016, 04:56 PM
  #63
5CHN3LL
5CHN3LL's Avatar
Originally Posted by groovzilla
You also need to figure that KK most likely didn't seal the bearing correctly using the proper sealant and good chance his install was subpar - mixing and matching IMS components is simply a ignorant shortcut/rookie move to save a few dollars.
Evidently, you have not read enough of the seller's posts. He is a master mechanic with MANY experiences that make him far and away more qualified than any of those rank amateurs who actually developed solutions and brought them to market. /sarcasm
I think what I'm most surprised by is the failure of the seller to disclose the facts about the retrofit, since he went on and on about what a brilliant plan it was - and in fact crowed for some time about how he and the buyer were of the same mind about the car, blah blah blah. The BSometer has always been pegged, but now I realize the scale was completely wrong and we were measuring BS in tens of units instead of the thousands that were being produced.
As far as the car - I suppose one could argue that the motor was flawed and the failure was just the result of that engine being one of the "bad" ones that came from the factory - but it can't be overlooked that the car did 59,000 miles on that crappy sealed carmaker-doesn't-know-what-they're-doing conventional bearing but only managed 7,000 miles on the hybrid bearing hand-selected by the previous owner. I don't give legal advice - but I guess one question the buyer might consider is whether the manufacturer of the bearing used would have prevented him from buying the car. The kit that was used (sans bearing) is already a lesser expensive product than other retrofit solutions on the market, so it doesn't seem that buyer's decision was predicated upon the use of the best (i.e. most expensive, most publicized, most discussed) retrofit product.
Finally - I recognize that we all have differing opinions about whether or not legal action is warranted - but calling out our resident legal expert as an ambulance chaser for proffering his opinion is a little harsh. Let's keep the vitriol focused upon the korrect party here...
5CHN3LL is offline
Old 04-14-2016, 05:27 PM
  #64
Imo000
Captain Obvious
Super User
Imo000's Avatar
To the OP:
KK asked me a few years ago when he was replacing his bearing about the bearing I bought to experiment with (it was sold by BOCA Bearing and I told him in a PM and in the engine repair thread "Dragged me home one of these", that what I did was an experiment, there was zero information on that bearing and I was willing to take a chance on my engine).
Fast forward to the Fall of 2014, when I took my engine apart again because of oil pressure issues after going to the drag strip. When I removed the bearing flange, noticed the experimental bearing was on it's last leg (luckily it hasn't come apart yet). Shortly after this I either sent KK a PM or actually posted in HIS engine rebuild thread that, he should contact the owner of his car (if he had the contact info) and let them know that the bearing in my engine didn't do so well and if anything, to at least check his. I haven't gone back to read that thread so only going from memory at the moment BUT I'm pretty sure he said he had no info on the new owner so......... here we are today.
As with all my threads on engine repairs, I always post the good and the bad. My 2nd engine repair thread (hosted on another Porsche forum but links are posted in original "Dragged me home one of these" named thread here on RL) was put on hold since last summer because I have been working on another car or other projects. My conclusion from my experiment was that the bearing I used (sold by BOCA bearings, double row hybrid with ceramic *****) is not suitable in my engine and the next one will be something different, perhaps I'll try a roller bearing instead (since those were not used back then so information was very limited on them). Things like this happen when you are experimenting but since KK knew the bearing he used didn't last for me, he really should have contacted the OP (like I suggested him to do) and tell the new owner "Hey, just and FYI, that bearing I used in your engine, you might want to keep an eye on because the only other person that used it (and was willing to share the data) had a failure.
Imo000 is offline
Old 04-14-2016, 05:33 PM
  #65
Ahsai
Ahsai's Avatar
OMG, too much to digest...
Ahsai is offline
Old 04-14-2016, 05:55 PM
  #66
5CHN3LL
5CHN3LL's Avatar
Wow. Things just got greasy up in here.
5CHN3LL is offline
  #67
Quadcammer
Quadcammer's Avatar
Received 1,369 Likes on 793 Posts
5th chair?
Was the outcome favorable to you?
Quadcammer is offline
Old 04-14-2016, 06:01 PM
  #68
groovzilla
groovzilla's Avatar
Received 4,424 Likes on 2,699 Posts
This hole keeps getting deeper. Should be getting close to China by now? Maybe even in the same proximity where the KK's failed $12 bearing factory is located.
groovzilla is offline
Old 04-14-2016, 06:09 PM
  #69
alpine003
alpine003's Avatar
No groovzilla, just to be technically accurate, I believe he decided to ditch the $12 bearing and use either the $35 or $45 ceramic one. LOL.
alpine003 is offline
Old 04-14-2016, 06:18 PM
  #70
Schnell Gelb
Schnell Gelb's Avatar
IMO said:
"When I removed the bearing flange, noticed the experimental bearing was on it's last leg (luckily it hasn't come apart yet)."
You are one of the brightest (& bluntest :-} ) Rennlisters for mechanical issues so your experience with a self-specified IMSB is particularly valuable. It is unlikely(?) you failed to do the pre-qualification checks or bungled the installation. So what do you think caused your first replacement Ceramic Hybrid bearing to fail ?
I understand that BOCA disapproved of this application for the bearing - but why? Do you have the specs on the bearing?
My interest is just the engineering an wanting to understand more about this issue.
Grateful for any ideas you care to share here. Thank you.
Schnell Gelb is offline
Old 04-14-2016, 06:22 PM
  #71
JayG
JayG's Avatar
Lucy splain?????
JayG is offline
Old 04-14-2016, 06:28 PM
  #72
Schnell Gelb
Please don't encourage him !
Old 04-14-2016, 06:33 PM
  #73
gnat
gnat's Avatar
Originally Posted by JayG
Lucy splain?????
Careful or you'll make him start calling everyone tinkerbells again
Go read his post history, he is safe to ignore.
gnat is offline
  #74
spruden
spruden's Avatar
Agreed. Mind blown.
Didn't someone have a TV show idea floating around in a thread somewhere?
spruden is offline
Old 04-14-2016, 06:44 PM
  #75
Atrox
Atrox's Avatar
Atrox is offline
Quick Reply: I bought KK's car(long story...)
