996 Forum 1999-2005
Atlas TD6MR Lift Review
Old 01-19-2017, 09:50 PM
  #31
Sneaky Pete
Sneaky Pete's Avatar
It worked great with the MaxJax I have when I dropped my motor on the 996 a few years ago. But I have to agree bigger is better.
Old 03-03-2018, 12:51 PM
  #32
BallVice
BallVice's Avatar
Curious gents - and I'll post some pics in a few minutes - BUT _---
I have a delima - I bought 2 6000lb lifts (one for me - one for my best friend)
Got it installed - but the Jack points don't line up over top of the lift. Obviously our little gems are unibody construction - so I don't want to turn my 997 into a Brick -
So feedback - I see you have a 997 on the lift - but it looks like the front jack points aren't making contact - anyone else had to deal with this - and what was your solution?
Pictures coming ---
Old 03-03-2018, 12:55 PM
  #33
BallVice
BallVice's Avatar
Default Pics of my issue
Old 03-08-2018, 11:24 AM
  #34
sumofparts
2nd Gear
sumofparts's Avatar
Default engine trolley
I made a engine trolley that is adjustable front and back and the wheels go around the outside of the lift.
This makes engine install and remove a easy one person job.And it can be taken apart and stored.
TheUnscented (05-27-2021)
Old 03-08-2018, 01:29 PM
  #35
Mike_A
Mike_A's Avatar
Originally Posted by Slakker
Just installed a MaxJax and love it!
Attachment 1126361
Yes indeed....I ve had one for a number of years. easily justified it by eliminating the $2500-5000 maintenace costs from dealers and indys. Probably paid for itself 30 times over
Old 04-11-2018, 12:32 PM
  #36
mykle57
3rd Gear
mykle57's Avatar
Default Just got mine!
But, I've got a question (to other owners)​​​​​ without any load on it, empty, how long does it take to lower completely from full height ?
Mine is taking a couple minutes. With a load it it takes only seconds. How long does yours take?
Old 04-11-2018, 07:25 PM
  #37
spruden
spruden's Avatar
I’ve never timed it, but it doesn’t move quickly that’s for sure. From full height with no load it will take several minutes. Your experience seems to mirror mine.
Old 01-31-2019, 08:06 PM
  #38
lanceyhoward2003
lanceyhoward2003's Avatar
Default Drop eng/trans
Originally Posted by george_west
It is doable, but only from one direction. I had to reverse mine. Also depends greatly on what you are using to lift the engine/trans. It was tight.
It looks like is being done over the hydraulic cylinders. What are you using to support/ lower the engine? Is trans also attached? Is there clearance to unbolt cv joints in this orientation?
Old 01-31-2019, 10:39 PM
  #39
cds72911
cds72911's Avatar
Looks like a harbor freight 1000 lb lift table...
Old 02-01-2019, 10:31 AM
  #40
george_west
george_west's Avatar
Yes, harbor freight lift table. Trans was attached. I believe there was clearance to get at the cv shaft bolts once the engine/trans was mounted and the lift table could be removed. I was using the extended height (truck/suv) lifting pads.
Old 05-27-2021, 09:03 PM
  #41
TheUnscented
TheUnscented's Avatar
Default MaxJack?
I thought I’d read that the MaxJack required 5” depth concrete floor. I’m not entirely certain, but I suspect that my garage (built 2011) has 4” floors except for where footers are. That sound right? If so, is there any solution besides cutting out a section and repouring part of the slab? Seems like that would be less stable
Quick Reply: Atlas TD6MR Lift Review
