Are the C4S & Turbo bodies wider?
Try as I might, I can't tell from pictures of the 996 generation...
Is the C4S a widebody?
Is the Turbo wider than the base 911?
If you know, how much wider? (Can I not see it because it's only a subtle difference?)
Other gen 911's I can see an obvious difference. But with it's more subtle lines, I just can't tell with the 996. If the C4S has a wider body, I'm considering it as a potential purchase...I always wanted a non-turbo widebody 3.2 Carrera or 993, but I missed them before their prices went through the roof.
Wheelbase 92.6 in (2,352 mm)
Length 174.5 in (4,432 mm)
4S & Turbo: 174.6 in (4,435 mm)
Width 1999-2001: 69.5 in (1,765 mm)
2002-2004: 69.7 in (1,770 mm)
4S & Turbo: 72.0 in (1,829 mm)
Height 51.4 in (1,306 mm)
4S & Turbo: 51.0 in (1,295 mm)
40th Anniversary coupé: 50.2 in (1,275 mm)
GT2: 50.2 in (1,275 mm)
Curb weight 2,904 lb (1,317 kg)
C4s and turbo/gt2are identical: wide body, later is 2wd and c4s/turbo are awd.
Diff is turbo has spoiler, ducts behind doors, and of course turbos.
Diff is a few inches, but it's deff noticeable in width and *** shot.
Narrow bodies include everything else including Gt3's
a good back up: http://lmgtfy.com/?q=is+the+porsche+c4s+a+widebody#seen
OP, as already pointed out by jhbrennan....by 2.3622 inches
C4S is the wide body non-turbo engine, with all the turbo models' bigger brakes/tires/suspension, and same wide body.
Narrow or C2 are a total different car.
2002-2005 were the C4S 996 years. they also get you the supersexy continuous rear red lens. AWD doesn't exactly suck to have either.
A widebody is pretty darn obvious IMHO
wow nice C4S in that photo
Originally Posted by 5CHN3LL
This is a question for John Ireland, international expert in wide body Porsches.
I'm not going to fault this guy for asking. It might be obvious for us but for those just getting into these cars the differences are pretty subtle.
I remember YEARS ago asking about the differences between the MK I and MK II 996s and was told the headlights were one of the biggest visual changes. I responded by telling people I saw no difference between them! I don't think I got a response after that but honestly unless you are close to these cars some of the changes that have been made really require more than a quick glance to realize.
N.B. pic below copied from this thread: https://rennlist.com/forums/996-foru...ody-width.html
Rocky Mountain High
