Durametric Communication Problem on K-Line 2
#61
Oh crap. I missed that post. That's really good info. Thanks!
#62
Just to let you know that I confirmed with the ignition ON.
Same voltage (1v), then my K line 2 is definitively in good shape.
Now the journey continue... to turn this air bag light off...
My mechanic call me back, he got new readers... I will perhaps let him a chance ... before I do a more radical solution to resolve my air bag light issue...
Thank you.
#63
Hi Guys,
Thank you.
Thank you.
Update:
My mechanic was finally able to read the airbag module. He did not really know why. Perhaps because I changed the SRS.
Anyway, he told me he cleared errors codes, give me my safety check, and chargerged me, of course :-)
Cleared code were:
Air bag light is on (01), Ignition driver (21), ignition circuit side airbag driver (29), Ignition circuit airbag (31), Driver belt buckle fault (45), Passenger belt bucket fault (49).
I dont why all these codes, perhaps because of my "new" used SRS module?
But the thing is: the air light is again ON...! :evil grin:
Then he cleared it, but did not check after... if the light will come back on.
This story is not done and I don't know which code is causing the light ON... return to the beginning. (except that I have my safety check :-).
I will see if my chinese cheap kiwis cable will help me to have codes...
But no error code with my standard ODB2 reader.
#64
See page 3... http://986forum.com/forums/general-d...t-connect.html
^^^ this person. I must track them down and kiss them!
So it went something like this. I emailed Durametric and asked for what turned out to the the Gen 2 cable. Instead they sent me a beta firmware update for my existing cable. I tried the update, no Bueno. They then told me it must be my car. I reminded them that I have two identical cars and it didn't work on either of them.
So again o asked for a Gen2 cable. So they sent me a new cable. I tried it, no Bueno. So i asked them if they had just sent me another new Gen3 cable? "Umm, yes. But we are sure it is a problem with your car." This is where I got very frustrated and informed reminded them that I had two cars and an entire thread of posts from people that were having no the same issue and that you had blamed it on their car.
OK. We'll send you a Gen2 cable. And it worked. It worked it worked it worked. I now have access to ALL modules, including air bags. Yippee!
When I get back in town I'm supposed to pull log files for both cables and send them the results. Hopefully they will be able to figure out the issue and fix the Gen3 with a legitimate firmware update. Stay tuned.
#65
#66
But in all seriousness, the way they have handled it is really lame.
#67
FYI guys, I finally bought a real Duramtetric cable on eBay.
And now, I can read correctly everything. What a pleasure! Then that confirm that my lines were OK, and my mechanic guys not as good with Porsche as he said... And Chinese fake Porsche cables very bad...
Then here the error code from the airbag module (I have only this code), related to my Airbag light issue, I guess:
45
Belt buckle, driver
Then I am looking to buy a new belt buckle... I am hesitate to buy a used one... but as it is for safety and it is know that the 986 have connection issue with the buckle... I think I will go with a brand new one.
I hope this will finally clear this airbag light! :-)
45
Belt buckle, driver
#68
That's me (aka "particlewave"). You can have a kiss, but I don't do tongue on the first date.
I'm glad Durametric is acknowledging this more, but they need to come right out and say it. Maybe make model/year entry specific to the ordering process so that they can provide the appropriate cable/firmware.
#70
The gen2's work fine. The gen3 cables are the ones that had problems. When did you get it?
#72
Most likely a gen2
#73
45
Belt buckle, driver
45
Belt buckle, driver
FYI, I changed the driver seat belt buckle. (with a used one)
And I cleared airbag codes with Durametric cable.
AirBag light gone!!! Finally!
tested multiple time, still OK, no more error code.
This is the end of my journey to resolve this airbag light!
#74
Wish i had found this thread before i started pulling my hair out trying to get my durametric to work on my 99 996 CAB. Can connect fine to the tiptronic and DME but nothing else, so as above K1 ok, K2 not ok.
Worked fine on PIWIS 2, cable worked on a 996 previously a few years back so seems like i am out of luck.
No one worked out a hack for the cable to get it too work?
