Any way to determine whether IMS has been changed
Hello!
I am about to purchase a 2001 996 c4. The current owner claims that the previous owner had replaced the IMS, when the clutch was replaced; however, he does not have any factual evidence.
Is there any way by which one could determine whether the IMS has indeed been replaced?
Cheers,
The Car-nut
Cheers,
The Car-nut
My understanding is that if it was replaced with a LN bearing there might be a sticker affixed somewhere - like near the bellhousing area and/or in the door jam?
I guess you could try calling LN with the VIN and see if they can look it up to see if they had a warranty registration for it. I don't know if they'd do that or not though. Even that's not definitive in all cases though (I wanted to keep our original so LN knows nothing about our car).
Proving it is the seller's job though. If they can't prove it, then they can't legitimately negotiate on it's existence.
Edit: Even if it has the sticker, I still wouldn't trust it without contacting LN or accompanying paperwork. It's easy to make such stickers much cheaper than actually replacing the bearing (haven't heard any stories of that happening, I'm just that jaded).
Don't get so caught up on the IMS. A certain portion of the time, owners end up changing the IMS as a reactionary measure after it's too late and the engine starts to shed metal. I see so many peeps treat this as a security blanket, only to encounter issues down the road.
Some, like myself, would rather buy a virgin car. That way I know what I'm working with and no hidden variables. You can also just factor that into the overall price if you're inclined to change it out.
If you're looking at a ' 01 and are concerned about the IMS, you should also be concerned about cylinder head issues as '01 tend to have the most issues according to some sources.
I look at it as a decent tool to see how many owner's it's had and where it has spent it's life, but beyond that I don't see much value in it.
From comparing over a couple dozen reports side by side, you're better off going with Experian's Autocheck service these days. Not 100% fool proof but better in that it reports more data.
