996 Forum 1999-2005
My 3.6 to 4.0 Project
Old 03-17-2016, 12:44 AM
  #166
AWDGuy
AWDGuy's Avatar
Originally Posted by Flat6 Innovations
Ouch... But a good save to catch that. Those dowels locate everything in associating with carrier alignment to the case halves.
Yes, I have specific content about these in the hands on class, and if you follow my guide from the class, you can't leave these out unless you try to! :-)
Do you have the other case alignment dowels in place that index the case halves to each other?
Jake, you wanna know the kicker?
I actually have a note in my "build book" from your online class - make sure you know where the dowels go. Both you and Tony mentioned it so I wrote it down.
f%$k me.
ah well. we're back to 4-5-6 install now.
and yeah, we had the dowels for the cases in.
Old 03-17-2016, 12:54 AM
  #167
Ahsai
Ahsai's Avatar
Are these two dowels both on the bank 1 case? I have two but those are solid.
Old 03-17-2016, 12:59 AM
  #168
AWDGuy
AWDGuy's Avatar
yes, I drilled mine out to pull them out as they were stuck in there good.
LNE instructions required all dowels removed from cases.
Old 03-17-2016, 01:29 AM
  #169
Ahsai
Ahsai's Avatar
No, what I meant was the same two dowels I have are solid dowels, not hollow like yours. Are you sure yours were hollow before?
Old 03-17-2016, 08:51 AM
  #170
AWDGuy
AWDGuy's Avatar
I hollowed them out to pull the dowels when I originally split the case last year
they are hollowed out 50% of the way and threaded so I could put a bolt in to get a good pull to remove it
Old 03-17-2016, 11:21 AM
  #171
Ahsai
Ahsai's Avatar
Got it. No wonder they have threads inside haha
Bummer you have to split the case but it's just more time and no harm is done. Jake did take the time to remind us about the dowels multiple times during assembly. They are easy to miss.
Old 03-24-2016, 09:14 AM
  #172
AWDGuy
AWDGuy's Avatar
back to where we were. got cyl 4 5 6 done last night. much more confident the 2nd time around. lol. still did a little prayer to the porsche gods though....
With easter weekend coming, and most parts in now, I am hoping I can get quite a bit done...
It's recommended I use dreibond around the chain boxes portion of the head gaskets, should that be applied to both sides of the gasket?
Old 03-24-2016, 09:21 AM
  #173
AWDGuy
AWDGuy's Avatar
re: dowels for the heads...I am looking at the pics on auto Atlanta and they aren't quite clear to me on how many and where they go, Ahsai, can you tell me where these things go? I took a look at my old pics too and I can't see anything in them...
Old 03-24-2016, 12:38 PM
  #174
Ahsai
Ahsai's Avatar
Will need to check my photos and get back to you.
Old 03-24-2016, 12:41 PM
  #175
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,293 Likes on 903 Posts
Two dowels per head. Fit them to the block first. Make sure they bottom before dropping the head on.
Old 03-24-2016, 12:54 PM
  #176
Ahsai
Ahsai's Avatar
Awdguy, you can tell who is doing this everyday
Old 03-24-2016, 01:27 PM
  #177
Ahsai
Ahsai's Avatar
They're below cylinders 4 and 6 as shown in the photo. Same on the other bank.
Name:  0728152252 (Medium).jpg
Old 03-24-2016, 01:33 PM
  #178
Flat6 Innovations
Former Vendor
Not today... Cam timing my version of the 964 engine, at 4.1 liters..
Not tonight, either... Finishing my 356 engine install...
Just finished a 4.2 liter 9a1 engine, though....
Old 03-24-2016, 01:38 PM
  #179
Ahsai
Ahsai's Avatar
Engine ****! Big quality difference compared to the M96/97.
Old 03-24-2016, 01:46 PM
  #180
Flat6 Innovations
Former Vendor
Yeah, the accountants aren't in charge around here...
Quick Reply: My 3.6 to 4.0 Project
