blown engine
#47
True enough but the symptom "rocks in a hub cap" indicates a high probability, though being able to drive the car after hearing that makes one wonder if it might be something else?
#51
Ditto. California car so, presumably, no severe cold weather starting risk across its history. Bad install of IMSB; water pump fragmentation; timing chain breach? Even if the cylinders scored, is this is foreseeable outcome? Odd.
#52
I've attached a photo of the (taken apart) oil filter showing the metal filings caught by the filter—if that will help (especially if someone knows what a trashed IMS bearing does to the oil filter). sorry for the size of the image
#57
I've had a similar engine issue.
The chain rails debris should be brown/dark brown
Magnetic debris -maybe IMS
Non metallic glitttering debris = crankshaft/rod bearings
White/grey granular - look at it under a microscope to see the shape of the particles. ceramic should be shards ,not spheres?
#58
That is a crap ton of debris. I found maybe half of one of those filter folds.
Next I found a glitter filled two row IMSB and then went on to find heavily worn out main and rod bearings.
I'm going to guess you drove that car 40 miles with five cylinders.
#59
also, no loss of oil pressure during the drive to repair shop, normal water temp, no check engine light or any dashboard indicators. If it wasn't for the noise, I wouldn't have been aware of any problem.
#60
So what exactly is your mechanic saying in order to charge $19K for a installed motor? That part isn't clear unless I mis-read something.
