blown engine
#961
Wow, dodged a bullet. Only as strong as the weakest link indeed. Makes me want to drop my sump periodically. What made you decide you want to drop the sump or do you do this at certain intervals?
Edit: Lol...asked the same question at the same time.
#962
I figured it's been 10k miles so it's a good time to check the sump. Sump plate removal and re-seal is really easy btw.
No collateral damage since the clip was caught in the oil pick up mesh. Didn't even get to the oil pump.
#963
You have done this before so know better than I do but I would avoid splitting the case again at all cost and replace with a 1-piece clip. I have run chains with the 1-piece clip starting with the chain drive on my go kart at age 11 and never had one come adrift.
#965
Has JR ever shared his upgrade for this issue?
#966
I haven't seen any. Perhaps he could come up with "Faultless clips"
I'll likely drop the engine and inspect the chains first before making decisions. Have to drop the engine whichever options I pick anyway.
#968
Damn, sorry to hear that Ahsai. At least you caught it early. I've used the one piece style master link clips for years on motorcycle drive chains. Only ever had one come off and it was a dirtbike that got dragged across rocks backwards...long story. For serious high power operations we used a riveted link.
#969
Thanks JTT. Yeah, at least I cauaght it early. Will swtich to the single clip design. Bailed out by Jake and Charles
Will be splitting the heads once I got the engine on the engine stand.
#970
Keep the pics coming and good luck!
#971
Yeah, AWDGuy also suffered the same if you remember.
I have a few options to consider:
- Genuine one-piece chain
- OEM (IWIS) one-piece chain
- Use a one-piece E-clip that covers both pins as opposed to two individual c-clips like I have now. However, not sure if a single E-clip is necessarily safer
If I go with one-piece chains, I'll need to split the case.
found the clip in my sump.
dropped engine, fixed the chain and sold the car.
Officially done with porsche 996's.
Good luck Ashai! You are a much more patient man than I am.
#972
I have patience but not much spare time haha Will update this thread again once I have more progress...
#974
Captain Obvious
Super User
Super User
When you find out where the link without the clip is, have a really close look at the groove that the clip was in. I have a feeling the groove is worn.
#975
