996 Forum
Sponsored by: LN Engineering
IMS Tube Totally Misaligned
Old 01-05-2015, 01:54 AM
jshalomo
User
Thank you Jake.
jshalomo is offline
Old 01-05-2015, 02:47 AM
Jake Raby
User
Jake Raby's Avatar
You'll get it... This HAS to be the issue, its the only thing that will shift the IMS assembly up, toward the crank.
Take pics and post them when you find it! This is so easy to screw up.
Jake Raby is offline
Old 01-05-2015, 08:25 AM
jshalomo
User
Will do.
jshalomo is offline
Old 01-05-2015, 09:46 AM
dporto
Super User
dporto's Avatar
Rennlist at it's best!
dporto is offline
Old 01-05-2015, 02:28 PM
aftCG
User
snip
As you turn the sprocket the chain will stay out of place because the next link just feeds right back into the same place. Look carefully to find this, and you'll be able to move forward again.
Interesting phenomenon. I would have pictured the chain sorting itself out as you rotated it, but now I see that it would just keep a hump in it while it spun. Great tip from Jake as usual (I'm apparently also sitting on a tube of 5900 I won't be using).
I bought an IWIS chain before I saw Jakes comments a while back. I checked my chain and it is 0.020" shorter than the old one. Wondering if I should cut bait and get a different chain.
aftCG is offline
Old 01-05-2015, 06:22 PM
Jake Raby
User
Jake Raby's Avatar
Fit that IWIS chain to the IMS sprocket and see how it fits... You'll find that it's tight, and too narrow.. Probably.
Old 01-05-2015, 10:01 PM
onewhippedpuppy
onewhippedpuppy's Avatar
Originally Posted by jshalomo View Post
OUCH!!! While I am ultra pissed that I have to separate the case again, I am really grateful for your expert advise as you just saved me a lot of time and further frustration. You simply must publish your engine building book....it would be worth its weight in gold. Thanks for bailing me out Jake.
I think we need a "Like" button.
onewhippedpuppy is offline
Old 01-06-2015, 01:27 AM
jshalomo
User
Tough to take good pictures, but the first one is of the chain not sitting properly on top of the sprocket due to several links on the bottom (not pictured) climbing on top.
The 2nd picture is of the chain seated properly inside the sprocket.
After the readjustment, I noticed that the IMS tensioner paddle loosened up, and the distance between IMS sprocket and crank sprocket increased by 7 MM or so.
Will have to wait for parts to come in from pelican to put it back together again, so I won't know until the weekend if everything is ok. As Jake stated, I noticed how easily it can pop out on its own, so I will definitely fasten the IMS flange as soon as possible after dropping the crank carrier back in.
jshalomo is offline
Old 01-06-2015, 02:01 AM
Dannyfumi
Dannyfumi's Avatar
Jake, When will the book be published?
Dannyfumi is offline
Old 01-06-2015, 04:31 AM
Jake Raby
User
Jake Raby's Avatar
There ya go… Thats the late drive, its much more difficult to goof this up with the late drive, but it is possible.
Its almost like I've done this a couple times :-)
Old 01-06-2015, 08:14 AM
jshalomo
User
As I recall it was a little bit of a struggle for me to seat the crank carrier on its dowels...I am guessing the chain must have shifted during that process???
jshalomo is offline
Old 01-06-2015, 01:46 PM
aftCG
User
That would be an easy time for that to happen. I did a dry run on fitting my bearing carrier to the case half and before I did, I decided to use a zip tie to simulate the function of the chain tensioner. It takes up all the slack, keeping the chain snug against all the teeth.
Once it's in place and the carrier is attached to the case half I can snip the zip tie and begin the process of installing pistons 1-3.
This pic may help show what I'm talking about.
There's no danger of forgetting the zip tie because I can't rotate the crank to install the pistons with this in place.
aftCG is offline
Old 01-06-2015, 02:51 PM
jshalomo
User
That's a great idea. Thanks for the tip.
jshalomo is offline
Quick Reply: IMS Tube Totally Misaligned
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
