Bluetooth or iphone connection for 2002 with Navigation
I'm looking to get some connectivity. Either Bluetooth with iphone connectivity to make calls or at least a iphone hookup. I heard there are connection that delet the CD player at the connection to the receiver. Is there a BT or iPhone connection for the navigation vehicles?
If the unit is a Becker unit or if you have the external CD player in the frunk, there is a good chance the Yatour unit would work on your car. You would have to pull the unit to figure it out.
If you need help, I've got all the tools or you could come over and we can take a look at it. |
Thanks for the offer Paul! I have had the radio out and it is a becker navigation unit. I believe you installed the BT in your car correct? Do you have a link to the kit?
Here is the unit (this one has an aux input and SD card input):
http://www.ebay.com/itm/Yatour-MP3-d...item4d21bafeb4 Then you need the Bluetooth add on: http://www.ebay.com/itm/Bluetooth-Ha...c8a393&vxp=mtr If you didn't see my post on the install, just search "Yatour" on this forum and it will pop up. It's super simple to install, but I would happily help you at my place if you'd want. |
So it works well? I might take you up on the offer if I pull the trigger and get it. The CD 's in the changer are getting old...
Works fantastic
Here's just the iPad/iphone cable. I used the one to connect a cd220, worked great;
http://www.discountcarstereo.com/iP-BKR2.html They have other options as well so check your radio and figure out what you want. I expect the yatour stuff works as well. That said, if you have the Bose (MOST) system, your best bet is to rip it and do a double din replacement. |
Hi, forgive me, I am new to this forum. I have recently returned to ownership of a 996 with the purchase of a 2002 c4 cab. I have replaced the cdr23 with a Becker traffic pro 7945 with bluetooth and it works fine. I have now just added the yatour ytm06 adapter and although the led on the usb stick is lit the traffic pro does not seem to recognise the yatour. I have changed the settings to external device but no sound. Can anyone offer any advice please?
Loppy: Are you sure it works with the 7945? That appears to be a modern unit.
I would try pulling the unit, remove the fuse on the back of the unit, wait a few minutes, and then put the fuse back and try it again. Or you need to do a hard reset of the unit, do you have the manual for the 7945? It most likely has a key stroke to do a hard reset which would then most likely cause the unit to re-initiate and see the Yatour. |
Hi, thanks for the reply. The spec on the yatour does list the 7945 as supported. I have tried removing the fuse but no luck. The manual describes a soft reset which I will try. But doesn't mention a hard reset.
