Brake Master Cylinder Differences?
Anyone know the physical difference between the 996 brake master cylinder parts 99635591040 and 99635591050?
I know the 1040 is for normally aspirated 996's with PSM (M476) and 1050 is for 996TT with PSM.
I ask because the 1040 can be had for $100 to $200. The 1050 is more like $500 to $600.
So, I'm wondering what it takes (if anything) to adapt the 1040 for use on a Turbo.
Former Vendor
The standard 996 master cylinder uses a 23mm piston, and the Turbo uses a 25.4mm piston due to the larger calipers. I believe everything else mounts up the same, so there's a good chance it will be a simple upgrade for Carrera owners. This would essentially would be a down grade for you and other turbo owners though, as you would be moving less volume.
ECS, appreciate the feedback.
So, the Carrera bore is about 15/16 and the turbo is 1"... The units look the same and should be physically interchangeable, as you suggest. Both have one M10 and one M12 port, which is convenient.
Since the stroke is the same, I basically need to determine if a 10% loss in fluid displacement is acceptable as well as living with 10% more pedal travel. Seems like it should be...
