996 Forum 1999-2005
My C4S photo journal
Old 05-09-2015, 01:59 PM
  #46
peteb3
peteb3's Avatar
Had a bit of a mechanical issue
Pressure plate failure
Started out I noticed a slight vibration in the clutch pedal the next day started slipping
Pulled it apart and found half the pressure plate fingers had collapsed due to a break in the structure
Ended up damaging the flywheel as pressure was being applied unequally
At least RMS and IMS look good
Still original IMS with 102500km
Decided to put in new RMS and LN IMS
Also doing new flywheel clutch AOS plugs fluids driveshaft guibo tranny mounts
might as well while I'm in there
Old 05-09-2015, 03:36 PM
  #47
911-140.6
911-140.6's Avatar
It's really too bad the the DMFW can't be re-surfaced cheaply. When I had my LN IMS/clutch job done I almost went with a Aasco LWFW but my track/street Audi has one and I thought it might better serve me to have a more daily friendly clutch such as the oem one. Glad I did.
Did you buy a good condition used or new FW ?
Old 05-09-2015, 03:41 PM
  #48
peteb3
peteb3's Avatar
All brand new Porsche pieces
Flywheel is definitely pricey
I'm lucky though as I get it wholesale price
Old 02-18-2016, 08:12 AM
  #49
peteb3
peteb3's Avatar
Picked up some hollow spoke Turbo Twists, looking forward to spring to try them out and to see if I can feel the weight reduction from the stock C4S Twists
Will need some tires as well
Old 02-18-2016, 10:40 AM
  #50
Hardback
Hardback's Avatar
Pete you can feel a slight difference in acceleration with the hollow spokes, the solids are quite heavy. Problem is mounting heavy r comps... I have both and experimented with all types of road and track tires on each set. I found mine on craigslist for $500 about 5 years ago. Did you get a good deal?
Old 02-18-2016, 11:13 AM
  #51
RedTele
RedTele's Avatar
It just keeps getting nicer. Good job!
Old 02-18-2016, 11:55 AM
  #52
Cheekybird
Cheekybird's Avatar
Holy slippery slope we are all on.....but at least I'm enjoying the ride!
Old 02-18-2016, 03:42 PM
  #53
peteb3
peteb3's Avatar
I got them for $600 CDN, or $435 in Greenbacks, so good deal I would say
Old 02-18-2016, 04:02 PM
  #54
Hardback
Hardback's Avatar
great deal man.
Old 04-19-2016, 03:50 PM
  #55
peteb3
peteb3's Avatar
Turbo hollow spokes are on, ended up having to get yet another set of new rears, yearly occurrence now, getting about 12000km out of a set of rears
upcoming service, decided to update a few things:
EBC red brakes pads and new Zimmerman discs also coming
and the usual culprits - oil service, transmission fluid service, diff fluid service, plugs, coolant, new wiper blades, etc
Old 06-09-2016, 08:23 AM
  #56
peteb3
peteb3's Avatar
EBC RED pads, new discs, and stainless lines are on, definitely feel an improvement in braking and brake pedal feel
Old 06-09-2016, 09:00 AM
  #57
dan_189
dan_189's Avatar
Enjoyed seeing all your mods, keep up the awesome work
Old 06-09-2016, 10:18 AM
  #58
theclutch
theclutch's Avatar
12000 km = 7500 miles! Why are you only getting that low miles out of them? Are you running them until the "wear bars"? Is it aggressive driving, track driving?
Old 06-09-2016, 03:30 PM
  #59
peteb3
peteb3's Avatar
That's pretty normal for a 220 tread wear rating tire,
I'm not sure the PS2s are supposed to last much longer than that, no track driving, just daily driving
I guess I could be wrong, what should I be getting on the rears?
Old 06-09-2016, 04:15 PM
  #60
Vdubjetta02
Vdubjetta02's Avatar
Your car is way cooler than mine.... nice build. You have everything I wanted to do when I bought mine however maintenance bills keep getting in the way of modding
*Getting married last month didn't help either
Quick Reply: My C4S photo journal
