996 Forum 1999-2005
FVD Brombacher - High Quality IMS Repair Kits are $ 495 - New Release!!
Old 03-21-2014, 05:45 PM
Rhonda@FVD
Rhonda@FVD's Avatar
Default FVD Brombacher - High Quality IMS Repair Kits are $ 495 - New Release!!
In our constant quest to bring our customers the finest quality parts we have just released our IMS Bearing Repair Kits. These bearings are made for us by SKF in Germany and use the best materials available from them to ensure reliability and longevity. These kits retail for $ 495.
IMS Repair Kit "M96. Single Row" Ceramic – FVD Part # FVD 105 901 03 - $ 495
There is a lot of information online about IMS bearing failures, why they occur, how to detect them, how to install an aftermarket bearing, etc. So there is no need for us to go into depth on the subject. Our stance is to sell a top of the line bearing produced to higher specifications than what was originally in the car and is currently available on the market.
FVD IMS Bearings are manufactured by SKF in Germany and are highest rated SKF “Super-Precision” class of bearings which are characterized by:
High-speed capability
High load carrying capacity
High stiffness
Low Friction
Our Single Row Ceramic Bearings consist of the highest grade ball material which are 100% ceramic. The ball lubrication is a vital consideration so we chose the highest available heat resistant lubricant which is good to 160 degrees Celsius. We also chose the most durable housing seal made for its re-lubrication characteristics. These facts allow our bearings to run cooler and allow SKF to guarantee double service life over standard bearings.
IMS Repair Kit "M96. Dual Row" – FVD Part # FVD 105 901 04 - $ 495
High stiffness
Low Friction
Our Dual Row Bearings consist of the highest grade ball material available in a dual row bearing. The ball lubrication is a vital consideration so we chose the highest available heat resistant lubricant which is good to 160 degrees Celsius. We also chose the most durable housing seal made for its re-lubrication characteristics. These facts allow our bearings to run cooler and allow SKF to guarantee double service life over standard bearings.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Want to learn more about us? Click here...
Old 03-21-2014, 06:11 PM
STAGGERWING
STAGGERWING's Avatar
Do these kits require special tools to install and if so what would total cost be ?
Thankyou
Found the required tool kit in your site for $195
Bob
01 C4
31 Ford cp chp & ch, 302/350
40 ******, 302/350
38 Ford cp, 327/350
57 Belair
62 356B --long ago
Old 03-21-2014, 06:12 PM
MiamiC70
MiamiC70's Avatar
Starting to get might interesting on the IMS front
Old 03-21-2014, 06:41 PM
Dannyfumi
Dannyfumi's Avatar
I wish I would have seen this 30 days ago Rhonda, I would have bought yours.
Danny
Old 03-22-2014, 01:20 AM
6ta1
6ta1's Avatar
seems like a good price!
Old 03-22-2014, 05:51 AM
Stephen Tinker
Stephen Tinker's Avatar
The flier says:
1) Nothing about the dual row bearing being fitted with ceramic *****, so I assume that standard steel is used in lieu of ceramic......
2) Looks like the bearings are sealed & not open to splash lubrication as in the LN Engineering retro fit upgrade. That means they are relying on the grease to lubricate.....
Are we going back to what Porsche originally designed but with a more expensive bearing - the dual row is sealed, it uses grease as it lubrication and it has steel bearings and race ??
Old 03-22-2014, 06:23 AM
Hurdigurdiman
Hurdigurdiman's Avatar
Well that posting should cheer up Jake no end. Plus a good few of the posters who went with Jake's replacement IMS bearing. Not heard from Jake in a while so maybe he has something to do with this new one.
Old 03-22-2014, 06:25 AM
318touring
318touring's Avatar
Originally Posted by Stephen Tinker
The flier says:
However re lubrication, not opened to engine oil
Old 03-22-2014, 06:43 AM
Stephen Tinker
Yes, I read that about the single row bearing, but as I said in my first comment "nothing about the DUAL row bearing being fitted with ceramic *****"....
One of the biggest arguments over the last million years was that the IMS failed because of its lubrication - or lack of it - when the grease was "washed" out by old engine oil.
Just when the IMS debates were dying down, looks like back to the future.
Old 03-22-2014, 08:16 AM
adcampo
adcampo's Avatar
Have these been road tested? Although I'm not looking forward to replacing my ims, it seems like LN Engineering is the proven choice.
Old 03-22-2014, 09:33 AM
Hurdigurdiman
Have the ones from LN Engineering been road tested?
Old 03-22-2014, 09:47 AM
STAGGERWING
SKF bearings have been around for many years & accepted as a quality bearing however I'd agree w/ adcampo that knowledge of actual testing for this application should be provided which I've also not seen from LN .
Old 03-22-2014, 10:17 AM
993GT
993GT's Avatar
^SKF is the king of bearings IMO
Old 03-22-2014, 10:31 AM
porsche951
porsche951's Avatar
+1 here for SKF. Should be interesting to see how this bearing stacks up vs. the one from LN Engineering.
Old 03-22-2014, 11:21 AM
BigShow
BigShow's Avatar
"IMS Repair Kit "M96. Single Row" Ceramic – FVD Part # FVD 105 901 03 - $ 495"
Quick Reply: FVD Brombacher - High Quality IMS Repair Kits are $ 495 - New Release!!
