FVD Brombacher - High Quality IMS Repair Kits are $ 495 - New Release!!
#91
Yea, I noticed quite a few have been absent. Jake has a stand in, Charles has been a little quite, but posting. I guess I missed the straw that broke the camels back. I try to stay out if it gets too heated.. Good to see you posting.
#92
Although FVD is our competitor, I'll be the first to say that **** happens and bearings do fail. If anyone sells enough of them, you will eventually have a defective one pop up. That's why we try our best to make sure that pre-qualification procedures are followed to the T. I don't know all the details on what happened above, but dual row bearings with twice the load capacity seem to be less sensitive to environmental conditions or possible internal defects.
It's good that it was caught early and a sealed bearing was used to try to mitigate any contamination of the replacement bearing. I hope a spin on filter adapter without bypass was put on to try to collect any FOD and that the pan is dropped several times in short succession to clean any lingering debris.
As far as FVD's kits not using a ceramic dual row bearing, there are none right off the shelf that are a direct fit as Boxman said, and custom means more $$$. Both the Single Row Pro and Classic Dual are make custom for us by the industry leader in ceramics. One guy pretty much makes them all in the US. For example, if you go into a Motion Industries for example and try to buy a ceramic hybrid bearing, it will end up coming from the same source, however our bearings are unique and are sold to no other company.
And the IMS Solution is unique as well in that it is patented, just like the Single Row Pro, and the Solution is as different as it gets from the IMS Retrofit, being that it backdate the IMS to a plain, oil fed bearing. Nothing to fail, so yes, if someone has a failure with the Solution, they must be trying really hard or be really special!
Everyone else are just imitators. FVD, just like TuneRS and others, used to be large consumers of IMS Retrofit kits until they decided they could make more money doing it themselves by doing it differently. Just stating a fact.
But one thing is constant among everything we do - we don't knock off competitors or copy people's products, like our competition is more than happy to do, or infringe on our patents. Everyone knows I make the RND Roller Bearing and the Pelican IMS kit. We make lots of products private label for other companies because it fits a niche the customer wants (like Pelican with a budget DIY kit) or SSF who wanted a quality roller bearing kit when they weren't happy with what was available that they would stand behind with their 2 yr / 24k warranty they give shops on parts.
#93
Everyone knows I make the RND Roller Bearing and the Pelican IMS kit. We make lots of products private label for other companies because it fits a niche the customer wants (like Pelican with a budget DIY kit) or SSF who wanted a quality roller bearing kit when they weren't happy with what was available .
#94
There are lots of items people don't realize we make for others. One of our highest volume products isn't even for a Porsche, but for light aircraft: http://zipperbigbore.com/
#95
Ironically there is a banner advertisement at the top of this page :This is the source of the failed single row bearing in this thread. Not a word from them to support their product just an ad."FVD Brombacher - High Quality IMS Repair Kits are $ 495 - New Release!!"
Who wants to be a guinea pig?
6 weeks later the banner ad has gone ................
This must surely be a hint to those who used the FVD bearing or a similar one to change it before it is too late.
#96
#97
I'm new to this forum, so I will throw my two cents into the fray.
I own a 2004 Boxster S and bought her with 25,000 miles on the clock in 2015.
I immediately shipped her to Flat 6 and had the "Solution" installed.
As of June, 2018, I have 50,000 miles on her.
I love the spin-on filter adaptor and the idea of a plain bearing.
Just install the "Solution" and start living life. It's cheaper to buy the right part and install it once, instead of constantly trying to band-aid fix with an inferior design over and over and over.......
The "Solution" allows me to make trips like this with zero worry.
Get busy livin'.
Get busy livin'.
#100
Notice the below is a spec not a warrantee...
"We also have the dual rows spec'd for 62,000 miles / 100,000 kms service life on each bearing.
FVD Brombacher - USA
Rhonda Roxburgh
Phone: 954-571-2050 x 1
Email: rhonda.roxburgh@fvd.net"
This is the only info I can find on the FVD website that mentions warrantee or lack thereof. Perhaps I missed it somewhere. Maybe vendor could direct me to the proper location on their site?
From their website
"Warranty And Disclaimer
There are no express warranties that extend beyond the description contained herein. SELLER DISCLAIMS ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR WARRANTY OF FITNESS FOR ANY PARTICULAR PURPOSE. SINCE SELLER CANNOT CONTROL THE MANNER OF USE OF ITS PRODUCTS AFTER THEIR SALE, SELLER WILL NOT BE RESPONSIBLE FOR ANY CONSEQUENTIAL OR INDIRECT DAMAGES. When Seller is acting only as a distributor of products manufactured by other companies, Seller expressly limits its liabilities to any guarantees extended by the manufacturer, which guarantees Seller will pass through to the customer. No warranty will apply if its products are in any way altered or modified after delivery by Seller."
I don't see any mention of "Product warranty is void if not installed by FVD"(post #1009 from IMS bearing failure thread)
From their website:
"We recommend professional installation for the IMS bearing. "
I must be missing something here...
Rhonda Roxburgh
From their website
From their website:
#101
LN Engineering practically won't sell the Solution to people who've had a previous IMS failure. For those cases, only a properly sealed replacement bearing + bypass mod (either spin-on or zero-cost DIY) is an option unless you've got enough money to do a complete rebuild anyway.
Just to be clear; the FVD Dual Row is not that. The Pelican kit is, or a DIY sourced closed bearing.
As far as FVD and those other companies that blatantly try to copy our products and fail, there is only one original. The rest are imitators. We used to sell our bearings to companies like FVD and several other purveyors of IMS before they decided they could make more money cheaping out on components and undercutting us. No harm, no foul. That's what we are here for. It's all economic stimulus. When the competitors' product fails, they can also call Jake. He loves helping people who make the wrong decision and bought the wrong parts.
#102
Former Vendor
#103
I have a dual row pro, another two years ill be due for a replacement ill go with the solution.
#104
Aircraft guys are easy to deal with, or at least Hal at Zipper Big Bore is. Great guy to work with. He's had engines blow up mid-air. Never lost his composure. He said our cylinders are stronger than the originals. He actually had a rod fail and he didn't know until he landed. Had a misfire but didn't loose enough power to make him think twice. Our cylinder took the impact of the rod repeatedly and didn't fail or even lose a drop of oil. Quite a sight to see. The same failure with a stock cylinder doesn't have the same result.
Actually, the first cylinders we made in any volume were initially sold into the 1/2 vw market. If you don't know what that is, google it. They were getting 50 horse at 3200 rpm constant duty out of a 2 cylinder (half of a vw type 1 engine - literally sawed in half) with our cylinders and making it last.
