996 Forum 1999-2005
The tale of the $6500 Carrera
Old 02-12-2014, 08:11 PM
  #151
Imo000
Captain Obvious
Super User
Imo000's Avatar
It'll be hard to beat. My total includes importing it to Canada.
Old 02-12-2014, 09:13 PM
  #152
alpine003
alpine003's Avatar
I lost track but where does Vasir need to net out to beat your record? I believe you still hold the record, right?
Old 02-12-2014, 09:53 PM
  #153
Imo000
Captain Obvious
Super User
Imo000's Avatar
I don't know if there was a record or not. Car was $5K, bringing home to Canada (fuel to tow, hotel, duty, taxes) was $1500 and to fix the engine and get it road worthy was another $2K. Total was $8500.
Old 02-13-2014, 10:28 PM
  #154
Vasir
Vasir's Avatar
So the mechanic reset the timing.
This is what he had to say on the invoice:
"CAM TIMING, RESET/CHECK (Bank2) after reset cam timing, run and check
for chain noise. FOUND: Cam timing way out of spec, reset, ran engine to check
actual values. Noise occurs on right side above 2500RPM, runs rough at idle,
however smooths out just off of idle. No damage should have occurred due to cam
timing. RECOMMEND: Remove oil pan to inspect for debris and give direction
for next step."
Tomorrow they drop the pan to see what color plastic is on the bottom; he's convinced its a tensioner pad that's bad, but I guess the different tensioner pads are different colors, so the debris should be at the base of the oil pan.
We'll see how it goes...
Old 02-13-2014, 11:17 PM
  #155
Adker
Adker's Avatar
Good news!!
Old 02-14-2014, 03:36 PM
  #156
Vasir
Vasir's Avatar
Got an update via email:
"Hi Ben, we cleared the faults after resetting the cam timing and got the P1324 cam timing out of position after.
We are getting large cam deviations due to the bad cam adjuster or rails on B2. So, with that said we recommend to remove the valve cover on bank2 to see what is needed to correct this and the bad sound above 2500rpm on the same side.
Regards, Ron"
And in the next email some time later:
"BTW, the oil pan inspection finding were only brown plastic bits, which is good. The brown bits are the rails for cam adjusters.
Ron"
So it seems to be the best of the worst news. Car will be back on the road sometime next week I think?
I figured I'd share my emails and what I'm going through with you guys incase one of you have similar symptoms and the like; makes me feel a tad better when I open my wallet to get the car fixed. Hah.
... Now to search for a roof rack and slim box- already started plotting out my road trip...
Old 02-14-2014, 04:31 PM
  #157
txhokie4life
txhokie4life's Avatar
The hydraulic tensioner paddles for the vario cam.
the tensioner spreads two paddles apart which the chain rides on
controlling the exhaust and intake timing cams relationship.
As you put pressure on the paddles it pushes out the rails.
Probably have grooves in them and/or are falling apart.
simple fix (relatively speaking).
M
Old 02-14-2014, 05:16 PM
  #158
Byprodriver
Byprodriver's Avatar
Guessing your pads will look worse than these:
Old 02-14-2014, 05:41 PM
  #159
Imo000
Captain Obvious
Super User
Imo000's Avatar
Awesome news dude!!!! I'm going guess that the grooves will be much deeper than the pic above.
If the removal of the valve cover does show worn pads, get the other side changed too. If they are originals they won't be far behind in wear.
They are only $20/set/bank (2pads/set).
Old 02-14-2014, 06:55 PM
  #160
Vasir
Vasir's Avatar
Okay. So I got the estimate today. It will be ready Monday afternoon- 1890 bucks after diagnosing and repair.
Not bad, $8400 Carrera. Fresh fluids and everything. I'll be taking it on a 1k mile trip at the end of the week.
Old 02-14-2014, 06:59 PM
  #161
roadsession
roadsession's Avatar
I am SOOOO glad you were practical and didn't cave into all the rabid fear mongering going on in this board. Congrats and enjoy.
Seriously - as much as I really respect Jake Raby and all he has done for the Porsche community, maybe it's just his writing style but he truly makes even KrazyK sound like an optimist. It got to the point where I actually stopped going to this site for a while.
Old 02-14-2014, 07:10 PM
  #162
alpine003
alpine003's Avatar
I believe you beat Imo000 by a buck. and you didn't have to go to another country to do it. Haha. Congrats!
Old 02-14-2014, 07:20 PM
  #163
Mhenry
Mhenry's Avatar
Well done and I hope you have a great trip
Old 02-14-2014, 07:46 PM
  #164
5CHN3LL
5CHN3LL's Avatar
The dude makes a living because people deliver broken Porsches to him every day. Expecting Raby to wander around swearing up and down that every 996 will do 200,000 miles is as absurd as the idea of the local undertaker standing on a street corner shouting that we're all going to live to be 100.
People have a proclivity toward freaking out when something unusual happens under the hood - the very rational fear of the unknown. Knowing that Porsches cost a lot to fix compared to Hondas adds to that anxiety.
This stuff aside - OP: congrats. Nice to see somebody take a risk and win.
Old 02-14-2014, 08:41 PM
  #165
bal
bal's Avatar
Okay. So I got the estimate today. It will be ready Monday afternoon- 1890 bucks after diagnosing and repair. Not bad, $8400 Carrera. Fresh fluids and everything. I'll be taking it on a 1k mile trip at the end of the week.
That's excellent! What's your roadtrip?
Quick Reply: The tale of the $6500 Carrera
