996 Forum 1999-2005
ROW M030 installation a DIY job?
Old 10-15-2013, 02:59 AM
CJWessing
CJWessing's Avatar
Default ROW M030 installation a DIY job?
Hey guys,
Thinking about getting a ROW M030 suspension kit, would this be something I could install myself? Never done any suspension work before, but have done simple DIY work (motor mounts, 997 shifter, brakes, etc). Would I need any special tools such as a spring compressor?
Just bought 4 Esco jack stands and a low profile jack tonight and want to put them to good use. Local indy wants to charge me $700 for installation and alignment.
Thanks!
Chris
Old 10-15-2013, 03:11 AM
Gawernator
Gawernator's Avatar
This the compressor I use, looks like price went up!:
OEM 25550 Strut Spring Compressor - Amazon.com OEM 25550 Strut Spring Compressor - Amazon.com
This one is less expensive:
Advanced Tool Design Model ATD-7561 MacPherson Strut Spring Compressor : Amazon.com : Automotive Advanced Tool Design Model ATD-7561 MacPherson Strut Spring Compressor : Amazon.com : Automotive
Old 10-15-2013, 03:13 AM
CJWessing
CJWessing's Avatar
Also anyone know of a DIY tutorial on how to install a suspension and sway bars?
Old 10-15-2013, 09:34 AM
Sneaky Pete
Sneaky Pete's Avatar
Yes this is a DIY........do a search for X74/030 installation. There are many threads on RL about this. If you don't have the time $700 is not bad pricing.
Old 10-15-2013, 10:04 AM
Loren
Loren's Avatar
http://www.renntech.org/forums/tutor...nsion-install/
Old 10-15-2013, 10:34 AM
Augustomf
Augustomf's Avatar
700 for instalation and allignment sounds like a good deal, allignment will be around 250 so he is charging 450 for the install, sounds good.
The install is doable at home but it will take much longer than an Indy without all the power tools needed, lift etc.
Here is a good write up: http://www.jackals-forge.com/lotus/9...uspension.html
Old 10-15-2013, 10:47 AM
TomF
TomF's Avatar
Great writeup indeed, except it's for a 993...
Old 10-15-2013, 02:44 PM
Augustomf
Augustomf's Avatar
My mistake when I saw M030 you know what came to mind
997 do it at the Indy, 993 was easier to work on.
Old 10-15-2013, 03:31 PM
mrtoro
mrtoro's Avatar
I did the ROW install on my c4s last summer. All wheel drive adds complexity to the job and of course frustration. It is very do able with simple tools. I do not own a compressor nor a lift. Take your time and be able to walk away from it when things get frustrating to avoid making mistakes.
$750 with alignment sounds almost too good. I would not cheap (not saying that shop is incapable by any means) out on the labor when the suspension is involved.
At the end it transformed the car and it was very gratifying to do job at home. I used the 996 suspension how to on rennlist after paying to become a member. Well worth it.
Old 10-17-2013, 01:47 AM
CJWessing
CJWessing's Avatar
Are there any bushings or a thing else that would be worth replacing while I'm doing this? Or just install everything that comes with the kit?
Thanks!
Chris
Old 10-17-2013, 01:50 AM
CJWessing
CJWessing's Avatar
Would you mind posting a link to the 996 DIY? I was just looking around in the 996 DIY section and didn't see it there.
Old 10-17-2013, 09:15 AM
mrtoro
mrtoro's Avatar
Checkout renntech.org. Look at the bottom of the page after clicking on 996 DIY modifications. You will need to be a paying member to access that page. I am happy to talk you through any questions you might have. Feel free to pm me your number.
Quick Reply: ROW M030 installation a DIY job?
