Problem with Litronic / Bi-Xenon headlights
I am trying to diagnose a problem with one of my headlights (other one works fine). Sometimes, when I turn on the lights, it does not come on - but if I turn the lights on and off once or twice, it will usually come on. I noticed this problem for the first time a few weeks ago, and thought it might be the bulb, so I changed it. Once the light comes on, it appears to be of normal/usual brightness.
So, assuming that the bulb is probably good, as I understand these things, the issue will either be with the ballast or the igniter. Would appreciate any insight anyone has on this.
Also, is the igniter integrated with the ballast? I can't seem to find the part number for the igniter anywhere.
I would replace the headlight switch first. Probably the easiest and cheapest first step. I've had to replace it on e and the symptoms are similar to what you describe
