1999 996 Fuel Filter
Greetings,
I have a 1999 Cab. I just ordered the plugs, filters etc... from Pelican. I researched DIY on the fuel filter and as I understand it, it's supposed to be located in a molded cradle on the coolant res. On my car, the cradle is empty. I found a DIY on 1999 Boxters and it says the FF is located under the car (evidently have to remove an underbody panel). I searched this forum and found nothing. Either a PO broke the pigtail off of the filter and ran the line straight, or 99's have an alternate FF location. I know this sounds dumb. Sorry for what I hope is a stupid ? But bottom line where is the FF supposed to be on a 99? I can't believe someone would just run without a fuel filter on a car like this. |
If it's a C2, it's under the car. Yes, need to remove some body panel. I have replaced one on a '99 C2.
Thanks for the quick reply.
It is a C2. Time for a manual. |
It's near where the front transmission mount is.
#1: Fuel filter is the aluminum cannister at the top of this photo (brown and orange electrical wire).
http://1.bp.blogspot.com/-P7kTcx7HQH...303_202212.jpg #2: Location is in the tunnel underneath, just a few inches to the right of the green circle in this photo. http://4.bp.blogspot.com/-3_-dTRqW-w...1600/photo.jpg |
Thank you all very much.
