996 Targa Rear Window Gas-Pressure Springs Failing
I worked with a guy named Lou, email me if you'd like his contact info. Very helpful, was able to choose the right lifts for me after I provided dimensions and some pics of the gas springs. He also put the electrical connectors on the springs, I imagine they're for the rear defrosters.
-Chris
hbchristopher@gmail.com
-Chris
zoomyracecar (10-31-2021)
Also have this problem -- QUESTIONS
My lift supports to the rear glass hatch on my 02 996 Targa are also failing.
CHRIS - thanks for tracking that down and posting it.
Yep, the left and right sides have different numbers per Stabilus (0694SB and 0695SX) -- and they are incredibly expensive.
They have electrical contacts on the ends (Stabilus calls these "ElectroLift"), and they evidently provide inputs maybe for the courtesy light and probably the rear glass defroster.
I checked LiftSupportsDepot.com and they do indeed list the Targa, but they say to contact them for info -- which I did (awaiting response).
MY QUESTIONS ARE:
1) Did you get some type of external spring from LiftSupportsDepot that fits over the lifts, or did they send you whole new lift for $18?
2) Did you find any difference in rear defrost and courtesy lights after installing the new stuff?
Pictures of the LiftSupport replacements would be good, if possible.
Thanks.
MY QUESTIONS ARE:
Thanks.
Stasha,
They were able to give me brand new gas springs with the electrical connectors for $18 each. Didn't have any problems with the courtesy lights or rear defrosters afterwards. The only issue I've had is that the springs aren't as smooth as the stock ones, i.e. the hatch will open/close slowly with varying force along the way.
Thanks,
Chris
Thanks,
Chris
Stasha,
Thanks,
Chris
Thanks,
Chris
I know this is an old thread, but I just ordered a set of rear glass gas springs for my '04 Targa from LiftSupportsDepot. They're $28 each now, as opposed to $18 as mentioned previously, but that's better than the OEM price. I'll post back here with my impressions once I get them installed in the next week or so (they'll probably be just fine).
I received the replacements from Lift Supports Depot and they're great. They're super strong, and the glass actually "pops" open now when I press the release button! All it takes is one finger to lift the glass a couple of inches and the springs take over from there. I love them - especially for the price.
I did learn a couple of things during the installation process though...
At least on my 2004 Targa, Porsche has soldered one end of the electrical connector - where it connects to the spring on the shaft end. Instead of desoldering the connector and resoldering it onto the new gas springs, I found that you can actually unscrew the "socket" from the shaft and pull the whole electrical connector off. I ended up doing this with the OEM springs and simply swapping the whole connector "ring" with the ones on the new springs. I'm attaching a handful of photos that will hopefully help.
Because you can unscrew the "socket" ends from these springs, I see no reason why you couldn't buy your springs from anywhere - as long as they're the proper length - and then move the electrical connectors over from the OEM springs. However, I will say that after talking with Lou over at Lift Supports Direct, it may be worth buying from him just for the peace of mind. He seems like a really nice guy, and he's very quick to respond!
+1 for Lift Supports Depot. Had a set sat on my bench to be installed for months, and finally did it today. Perfect fit, re-soldered mine rather than replace the connector since the solder work at one side needed replacing
Just wanted to add another +1 to the Lift Supports Depot. I ordered a set of struts on Friday, received them on Monday and just installed them. Took less than 20 minutes. Thanks to Fixxxer for the tip about swapping the electrical connectors over. The solder on both of mine were good so it made it even easier.
One thing to note is the price has gone up: They're now $69.00 for a pair. Still far better than the $500.00+ for the Porsche ones!
Fixxxer (08-24-2019)
Hate to be devils advocate here, I have a 2002 Targa po bragged about how much he saved on hatch shocks. They are so stiff that I have to watch it like hawk if I am with another person. Some person who puts there hand on one edge to shut the hatch will break the glass. Its thin and you can see it bend. It must be shut with two hands. Any of the top or rear glass breaks you are gonna be in a world of trouble. Ever price the rear glass? You don’t want too...
Strange. Are they from LiftSupportDepot? Mine feel virtually identical to stock except now they don't sag.
I usually lower the glass with one hand in the center and then press it down with both hands so the lock engages. Don't know if that's the "proper" method or not.
I have a similar issue on the ones for the back of my jeep , they are too much force.
I think they are re-using too many part numbers to reduce inventory/overhead..
How did you make the electrical connection?
