tiptronic emergency run mode fault msg and error codes
So yesterday, I'm driving along the highway, and suddenly get a Tiptronic Emergency Run message on my dash. I pull over, turn off the car, but can't get my key out of the ignition - after much jiggling it comes out. I restart the car and the fault message is gone and transmission returns to normal mode but left headlight is out.
I got home, replaced ignition switch and headlight works fine and key comes in and out fine. I plugged in the durametric and got these codes: https://lh3.googleusercontent.com/-1...h749-no/13+-+1 I cleared the codes, reset adaptation, and went to sleep. This morning I drove into work, no error message, transmission is fine. Are the ignition switch and error msg related? Could it have played havoc with electrical signals? Oh BTW I had the dealer replace transmission fluid and differential fluid 6,000 miles ago. |
So, I changed the ignition switch, reset adaptation, cleared codes, and all was fine for 2 days.
Then I get this today: DME: P0715 Porsche fault code 552 Tiptronic supply voltage speed sensors Tiptronic: 13 RPM Sensor N3 and of course the "emergency run mode". any ideas? |
Hello
Iam having the same problem . What did you do ? |
Originally Posted by bader
(Post 12074486)
Hello
Iam having the same problem . What did you do ? http://www.renntech.org/forums/topic...ency-run-mode/ |
Thanks for the link. That solved my issue as well!
2001 996TT |
Hi guys, the Tiptronic emergency run can up on my cayman s 06 while i was taking a trip. I stopped the car turned it off and everything ok. But now its doing it lots. Now I have a check engine light. I took it to the porsche dealer and they said i need new shifter cables. Any info on this?
Originally Posted by Josh Gonzalez
(Post 13543123)
Might be worth asking asking the Cayman owners also: https://rennlist.com/forums/porsche-...nerations-126/ |
I get this one when I first start up my car...
Not sure what it means... looks like German, but when I go to look for error messages, this one pops up. https://cimg9.ibsrv.net/gimg/rennlis...c8de90daa7.jpg |
Originally Posted by Jeremy Wight
(Post 12828870)
2001 996TT |
Originally Posted by b3freak
(Post 13545843)
Not sure what it means... looks like German, but when I go to look for error messages, this one pops up. |
I had the same problem for a long time where it would pop up at random. One day, the error could not be cleared no matter how many times I turned off and on the ignition, nor tried clearing the codes.
It was solved by switching out the conductor plate in the transmission. Here is the full thread: https://rennlist.com/forums/996-foru...gency-run.html Good luck! :) |
