Have you tried this method to put your car on 4 jackstands?
I've had my cars in for many a service or pre-trip roadworthiness inspection and the techs never lift the cars by any other points other than the lift points.
The only time I can recall I've seen a floor jack used to lift a car at the dealer I use is when I had my totaled Cayman S there and the tech used the floor jack -- the car was not drivable -- to lift the car up so the exotic car adjuster could see -- from a safe point from the side of the car -- the extent of the damage some items under the car.
So Macster, if the factory designated jackpoints are the only points one could use to lift the car, then for those who want to work on their car but lack a hydraulic lift in their garage, the only solution is to take it to a shop where said lift is available?
While the location you are using to lift the car may be convenient it is not a proper location to lift the car, not one recognized or sanctioned by the factory, at least not in any of the official service references I have access to.
So your last sentence above should read: "That's the wrong way to jack up the rear of a 996 so this whole discussion is kind of wrong."
Personally I cannot see any risk with lifting the car in the cross member. The entire car is resting on the wheels that are attached to the cross member!
Robert
Screw it. I'll just put in some 996 cup car air jacks so I don't have to worry about my lift points...
Hmm... Wasn't there something about only jacking a car on flat (horizontal) surface? Maybe it's the camera angle but I notice quite a grade on this pic. Plus, the engine is at the "bottom" end.
