What Else to Change While Engine is Dropped?
Its getting closer to engine drop time and Im thinking of a to do list while its out. So far Im thinking:
Clean / detail work
AOS/Oil Vapor Seperator
Water pump
Low temp T-stat
Any worn coolant hoses
Pulleys
Variocam Solenoids / seals
Plug change again(1700 miles / 7 months old)
Coil packs
Inspect my recently replaced new flywheel / clutch / RMS/ CH IMS bearing
I have no oil leaks so not sure what else to include. Any suggestions? Hey and dont hassle me about working on my car. Its a great learning experience for a n00b like me.
Clean / detail work
Water pump
Low temp T-stat
Pulleys
Coil packs
That's a good list. I would suggest:
* adding fuel injector cleaning and testing.
* test the cam hydraulic lifters
* the pulleys are superceded by a 997 part number
* motor mounts
* motor mounts
KrazyK: It is UNFAIR to not drive your C4S the way you do. Please resist the temptation of dropping that engine for a year or so, while you enjoy the car for a while. De rien, mon ami!
Clean / detail work
Water pump
Low temp T-stat
Pulleys
Coil packs
Clean / detail work
Water pump
Low temp T-stat
Pulleys
Coil packs
Replacing the solenoids is from what I understand is easy peasy.
Why not go deeper and replace the VarioCam actuators?
In fact for some of the work you're talk about doing is from what I gather just repeating what you've done before. Where's the learning in that?
Next time your drop the engine split the cases. Check crank mains/rod bearings for wear. Measure crankshaft end play. Check crank for straightness. Have it checked for cracks. Ditto the rods.
Do a valve job. Verify valve spring pressure is ok. Bleed down test the lifters.
Rebore the cylinders and fit custom oversize pistons.
Captain Obvious
Super User
Super User
Clean / detail work
Water pump
Low temp T-stat
Pulleys
Coil packs
Clean / detail work
Water pump
Low temp T-stat
Pulleys
Coil packs
Captain Obvious
Super User
Super User
Besides I thought you wanted to learn new things.
When I wanted to learn engine rebuilding I rebuilt an engine that had supposedly been rebuilt not too many miles prior to me buying the engine.
And when I finished the engine rebuild I removed a perfectly fine engine from the car.
Captain Obvious
Super User
Super User
How do you know unless you check?
slave cylinder
trans reverse light switch
trans mounted SSK
2nd gear hardened pin
engine mounts
RMS
swaybar bushings
sandblast & powdercoat subframe connectors
any exhaust mods
coolant reservoir if your's is bad
trans mounted SSK
engine mounts
RMS
swaybar bushings
any exhaust mods
