Narrow body wheel question?
They never made the hollow turbo twist wheels pictured above in NB offsets. Most likely the rears are gonna be 45mm offset for Turbo/C4S models.
The older turbo twists were made in both hollow and solid and were available for both NB and WB offsets but those are the older turbo twist look and the hollow ones should start with a "993" part number IIRC.
Correct. The older turbo twist style came in both WB and NB as well as solid and hollow spoke. Both WB and NB will have both 996 and 993 part numbers. However, what I was trying to say is the NB older turbo twist hollow rear wheel will most likely only have a 993 designation. Sorry if my previous post seemed unclear.
