Anyone running eGas ported throttle body here?
#47
I've dyno'd 3 maybe 4- X51's with the highest reading being 309 rwhp on the Dyno Dynamics dyno. That car will be there this weekend so I can make a apples-to-apples comparison. Regular old 3.6's make 280-290 by comparison on that same dyno, a difference of only 20-30 rwhp (=/-). YMMV....
FWIW my motor, 3.6 bottom with 3.4 heads (lightly decked), OEM cams, & FVD cable TB hit 305 rwhp on that Dyno Dynamics dyno. It produced awesome TQ in that configuration but didn't much like it when I hit 8600 twice in a race. Boom.....
#48
Nice. Do you have a pic of the dyno somewhere? I would love to see the whole curve instead of just reading about peak figures.
#49
JR, I guess the sea level air in Texas is better than the sea level air in Calif.
No one give me crap for the fuel curves, etc, the final tuned dyno was higher, tq moved some, and with better AF ratios. It is a 3.6 X51, race car, NOT a street car. Stock Porsche unopened block,heads, crank, although various add ons, "Special" tuning package, etc etc etc. Oh, and on a Dynojet.
#51
Thanks. It does ok for a stock block/heads/cams/valves motor.
Although I have been planning something new for even more tq and a better curve, hopefully it will all work out as I have planned.
#52
NASA adds 10% to the Dynodynamics readings so 309 + 10% gets me right up next to your dynojet results. I did however find a X51 at 315 on the Dynodynamics maching. +10% for that motor woudl be 346.5...
#54
Thanks JR, those are some great numbers for your frankenstein setup.
In my experience, the Mustang style dyno's generally read a bit lower than the Dynojet roller dynos.
Seems like you got some decent broad powerband. It seems like you are gradually dropping off above 6.5k though. I wonder if the x-51 intake manifold allows the power to keep going as in Viking's graph above 6.5k?
#55
Former Vendor
That said, we do everything possible to make peak power at 6.5K or below, else I have learned that we have to use our solid lifter/ solid tensioner package that requires valve adjustments. The factory X51 engines make power right up to the rev limiter, which is very hard on the factory hydraulic valve train. Not even my modified hydro lifters are able to hold up with constant redline operation as well as our solid arrangement.
The solids are a bitch to deal with, but to really turn it up we have learned what needs to be done..
#56
^^^ Thank you Jake for that wonderful piece of info.
So since the stock lifters are the weak point at high rpms, does one even need to worry about valve float since there would be no point in running high rpms, at least on a constant basis?
Also are you sure you're feeling ok?
I've only heard technical responses from you with no sales pitch whatsoever lately. It feels like I'm reading your older posts lately. I mean that in a great and refreshing way. Either way, thanks for the insight. Truly appreciated and what forums should be about.
#57
Former Vendor
Actually I had oral Surgery today and am pretty much whacked out of it after having 5 teeth cut out, but trying to get a newsletter finished and etc.
I didn't think that I had changed anything in the way that I post. I have been posting less as I just don't have the time. I enjoy posting and helping most of the time, but other times its just another form of stress that I need to avoid.
#59
I have tested them back to back, and yes the X51 will help, BUT not as much as the head work from the X51 does.
in Viking's case... this doesn't apply as there is good solid top end power.... but the top end stress on the motor is still there and will materialize over time..
#60
egas Tb is that much smaller than a nonegas? Regardless that's a nice size gain...
