Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Reload this Page >
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
996 Forum
Sponsored by: LN Engineering
View Poll Results: Has YOUR car suffered an IMS failure
Yes, the IMS failed
9.76%
No issues with IMS
90.24%
Voters: 1189. You may not vote on this poll
Old 06-24-2019, 09:24 PM
  #1081
Tsterry
2004 C4S 61,000 miles. Changed IMS with Clutch in February 2019 for superstitious reasons.
Tsterry is offline
Old 06-24-2019, 09:39 PM
  #1082
996AE
996AE's Avatar
Aftermarket trolling for IMSB failure is only second to new, first time posts; what oil should i used in my _____________.
Sleeping better or worse after removing a perfectly good part for a new, but now a wear item parts?
996AE is offline
Old 06-25-2019, 08:40 AM
  #1083
Tsterry
Sleeping better, thank you. No more nagging sense of possible doom. Absolutely worth the expense.
Tsterry is offline
Old 06-25-2019, 12:47 PM
  #1084
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
So you'll be going back to your "perfectly good" IMSB that was removed recently?
Scott at Team Harco is offline
Old 06-25-2019, 01:00 PM
  #1085
808Bill
Super User
808Bill's Avatar
Wake up! Bore scoring is the new IMSB...
808Bill is offline
Old 06-25-2019, 01:03 PM
  #1086
996AE
996AE's Avatar
Trolling for dollars...
You have to admit the aftermarket parts guys have done an exceptional job creating the market for paranoid 996 owners.
996AE is offline
Old 06-25-2019, 01:14 PM
  #1087
808Bill
Super User
808Bill's Avatar
Not according to anyone that lost a motor because of it. Seems like a no brainer to me. Except, I would go with the LN Solution and never worry about IMSB again. Do it once and forget about it!
808Bill is offline
Old 06-26-2019, 09:35 AM
  #1088
buccicone
buccicone's Avatar
Ain't that the truth!
buccicone is online now
Old 06-26-2019, 09:36 AM
  #1089
buccicone
buccicone's Avatar
That's where I'll put my money.
Old 07-01-2019, 12:41 PM
  #1090
z driver 88t
z driver 88t's Avatar
1999 C4. Original dual row bearing was replaced with clutch at 94K miles in 2015. Bearing was fine with no signs of wear. New dual row LN IMSB installed at that time. Currently at 125k miles.
z driver 88t is offline
Old 07-04-2019, 07:43 PM
  #1091
GarrettSR5
User
1999 C2 with 130k on original bearing. Porsche indy had no problems to report
GarrettSR5 is offline
Old 07-10-2019, 01:48 AM
  #1092
Dmhager
Dmhager's Avatar
2001 C2 cab with 50k miles, dual row bearing, 2nd owner. Replaced my IMSB with the LNE Solution, replaced original clutch/pp/fw/bearing/lever (clutch worn 40%). Everything was perfect: no leaks, clean oil inside the IMS, lovely 2 row bearing in pristine condition. I drive 3-5k / year and use Motul 5w40. I did have to replace bank 1 variocam pads that were pretty badly pitted and the cam deviation was running about -8 degrees (no code). The most noticeable improvement is smoother uptake when releasing the clutch in first - although the original clutch was lightly worn and the flywheel functioned according to specs, the new hardware seemed to make a significant difference. The second most noticeable difference is that I no longer worry about the IMSB failing, but I worry about that little oil feed line chafing. Ill get over that - the IMS Solution is a nice piece of kit.
Dmhager is offline
Old 07-10-2019, 10:34 AM
  #1093
dporto
Super User
dporto's Avatar
"but I worry about that little oil feed line chafing."
Chafing on what? It shouldn't be making contact with anything. If it is, adjust the fittings until the line doesn't touch anything. If you can't, just put a piece of rubber tubing around it...
dporto is offline
Old Yesterday, 04:47 PM
  #1094
RoryMcPedal
99 C2 manual with 158000 KMs (~100,000 miles). Factory IMS, no failure. However, right bank ticking, as in "ticking time bomb".
RoryMcPedal is offline
Old Yesterday, 11:44 PM
  #1095
DrMEMS
DrMEMS's Avatar
The ticking could be a sticky intake valve lifter. I had that on my 2003 996.2. My indy dropped the engine and replaced all six (two per cylinder) on that side.
DrMEMS is offline
Quick Reply: IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
