View Poll Results: Has YOUR car suffered an IMS failure
Voters: 1590. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
#992
14002 would be a serial number for a dual row IMS Retrofit, manufactured July 2014, so it is possible that it has one of our bearings fitted, but I would have presumed they would actually put the part number fitted. If I were the customer who paid to have it installed, I would have questioned the lack of detail.
If it is kit sn# 14002, it was not registered with us, so I don't know what the condition of the original bearing was or if the job was properly qualified. Bare minimum, they should have dropped the sump which you will find sealant listed on the workorder which is a likely indicator that the sump was dropped. Usually most shops will charge several hours extra labor for these extra checks, depending on how thorough they are, and indicate cam timing deviation numbers on the workorder or other notes from the inspection, like "sump was clean."
If you don't want to publicly share the workorder, you could always PM it to me so I can look it over. I could also see if we sold a bearing to the shop that put it in, etc.
That said, it's likely not an IMS bearing noise as we've have never seen one fail in over 10 years of offering the dual row IMS Retrofit. I would first pull the filter and also sump to be sure and go from there. There are lots of things that can make this noise. I've seen catalytic converters make the same noise.
#993
Someone had to "knock on your window" and tell you that your car was making that noise? Seriously? Do you have a problem with your hearing? Let me guess, you had your favorite Gwar CD cranked up to 11 ? I wouldn't start that engine again until you figure out what's going on there...
#994
#995
#996
https://cupspirit.com/roulement-arbr...le-rangee.html
It looks very much like the shielded dual row bearing kit from FVD that there was a thread about with a similar failure about a week or so ago. If not, it's a copy of their kit.
#997
2004 C4S with 16k miles and original IMS. Purchased at 13k miles from original owner. Changed the oil twice already, once a year or 3k miles, whichever comes first. Plan to do this until clutch replacement or Indy recommends IMS replacement. So far he said it's not needed (I'm sure the board won't agree).
#998
#999
Not to say it's going to fail, but to enjoy the car for years to come
In comparison, its a small amount of money in the cost of ownership to the alternative
#1000
#1001
I'd really re think this as an owner, you should have this car pre-qualified for a IMS Solution or at the very least a replacement ceramic bearing
#1002
copy that, I bought a 26,000 mile 2004 Anniversary car in 2014
after a thousand hard miles, I decided I would keep the car long term and had the IMS changed
X51 engine is an expensive replacement
#1003
I did a search and found a kit with the part number 014002:
Installed bearing is a FVD dual row as noted on the invoice.
Question is : How can a new IMS bearing fail after 16000 km (10000 miles)?
The car had 3 oil changes, the oil filter was cut open after each change and found free of metal shavings.
#1004
jc, I'm so sorry!
There are a number of different reasons this could have happened...
