View Poll Results: Has YOUR car suffered an IMS failure
Voters: 1591. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
#871
Once you pull the transmission you can see the flange. If it is a factory flange you will see one of 3 things:
1) A shallow "bowl" indicates a factory dual row.
2) A deep "bowl" with a small nut indicates the original single row that can be replaced with the motor still in the car.
3) A deep "bowl" with a large nut indicates the upgraded single row (in a 996 it means it got a replacement motor after the 997s were out) that can not be replaced without tearing down the motor.
Left is a single row flange and right is a dual:
When you start talking about the aftermarket replacements, I don't know how much you can tell from the flange.
#873
Yes it's a very high quality copy of the factory RMS tool and $500. I'm willing to rent to help recoupe my cost on it - PM me. Also have all the LN IMS tools including the faultless. They all worked great and I have several thousand miles on my 986 fix.
#874
#875
What year was it installed? You still cannot tell for certain unless you see it with your own (or your mechanic's) eyes. Did they take a picture at the dealer? Since they did not offer to replace it, it is likely you have the 2006-2008 bearing. Sadly, this still fails.
#876
Unfortunately I don't know when it was installed or at what mileage. The PO didn't even know it had a replacement engine so I found that out myself. I'm not worried about it failing, I really was just curious. I'll just check it when it's time to do the clutch.
#877
2001 Carrera 4 Cabrio with 105k miles. Had RMS leak, decided to have LN Engineering IMS installed as well as a new clutch since my mechanic was already in there (among other things). Original bearing was still fine at 105k.
#881
Quite the opposite. I could barely afford to change the oil last time I did it. A 911 is something I probably shouldn't own, but the kids and I are having a blast. I have a cheaper car that I can drive if death were to strike.
#883
I know the percentage has nothing scientific behind it but it is an indication with both polls over 1000.
