View Poll Results: Has YOUR car suffered an IMS failure
Voters: 1607. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
#526
Update
2002 996 6speed 84000 miles no ims or engine failure, still original clutch. I replaced ignition switch $14, brake switch $29, cracked coolant tank $120, battery $90 , tires and maintenane (Mobil synthetic 0w-40 one a year). I'll inspect the ims during clutch. You should own a Porsche if either rich or a DIY, cuz driving a Porsche under paranoia is not fun and you'd better owning a no headache Toyota Corolla.
#527
IMS failed
Bought my 1st Porsche, 2002 Cab w 42k miles 2yrs ago, IMS failed 20hrs after driving off the lot!!! Thank God Dealer was good guys, they sent back check and picked up car!! Yes, I bought another 996
#528
Sorry you lost your first pick, congrats on the replacement.
#529
Good to hear the dealer took the car back! I'm amazed you still got another 996. That situation might have scarred me off...or at least made me buy a car that already had the IMS addressed.
#531
Did the report mention anything about the IMS/IMSB and other warranty work?
#532
the Carfax report listed a lot of general fairly major work, so I called for specifics. I gave s# and general date of work and they gave me a lot of info w part descriptions and they were very nice. Dealer in Charleston, SC.
#533
2000 - C2 - 94000 miles - No issues whatsoever.
Now the caveat - I purchased the car in CA from a dealer friend who had been driving it and picked it up at an auction (The car was originally from NY). This was in 2014 b/c I did not want to take either of my cars to Italy with me. I run Castrol synth 5-40. Most driving is a high(er) speed between here, Germany and Croatia. So, what this means is I do not know if there has been any prior problems with the car. The only original info on the car was via CARFAX which I take with a grain of salt. No record of clutch replacement/RMS either. GREAT mechanic here and not expensive.
#534
'03 c2, 102k miles, LN bearing installed preventatively at 80k. Runs like a champ.
#535
No issues, replaced RMS, clutch and IMSB with dual row pro 2.2 at 73k (kms) as preventative.
Old IMSB was in perfect condition now at 81k (kms). Fingers crossed no engine issues to come.
Always serviced at the dealership annually with M1 0-w50.
#536
Hi all, Interesting read. I have a 2001 996 112k miles, IMS catastrophic failure. Bought a 1999 60K mile core motor with Variotiming tensioner failure and dual row IMS in the process of failure.
I was told my original motor had a IMS failure but instead spun a rod due to Connecting rod bolt coming loose. IMS was perfect.
#539
IMS Problems?
Purchased my 2000 Cab last December. Seller was up front about "slight oil leak", PPI stated either RMS or IMS leak. Drove car 2000 miles then replaced IMS-it was fine -no problem and RMS-which was the source of my leak-as expected.
While back there-replaced clutch kit, found water pump showing singns of leaking-replaced and Oil Cooler also showing signs of leaks-replaced as well as well as all fluids and belts-including trans oil.
Been enjoying for a full year and looking forward to many more!
#540
I have a 1998 996 with the standard? 3.4 300hp engine,
No failures of anything yet except the manual seat button doesn't work on one of the seats not that I use it but its noted, she has done 114000 kays so its still quite low as a matter of course the IMS was upgraded by a PO so I guess she will be fine.
