View Poll Results: Has YOUR car suffered an IMS failure
Voters: 1591. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
#166
'99 C4 Aero. Engine replaced at 134,000 due to debris on highway taking out oil filter housing and starving engine of oil. Just bought car after engine replaced with 61,000 mile used engine by PO from a wrecked(t-boned) '99. PO upgraded IMS bearing along with other items on replacement engine during install. Technically, that's 2 engines without IMSB failure, but just voted once.
#167
How did your engine fail? Did it stall and then couldn't be restarted? That could be the end of an ISMB failure as it would indicate that the timing jumped and the valves crash landed into the pistons....in which case your mechanic would not be talking about a "clean out" and new bearing.
If you are lucky and your ISMB is just beginning to fail, you may walk away from this with just an engine flush (although that is pretty dubious and probably difficult to do properly) and a new bearing.
#168
I'm sure someone more knowledgeable will chime in, but I'm not sure why you'd have to pull the engine to flush the engine or install a new oil filtration system. Also, a high percentage of the M96s do not have failures, so that would seem to indicate that it would be cost prohibitive and ill advised to change the oiling system simply because you had an ISMB go out - especially because the new bearing should be good to go for a good long time with the stock oiling system.
Regarding how it happened: initially I thought I caught this problem early, after all, my car was still running well when I brought it into the shop. It had a low grinding whine coming from in between my transmission and engine, like someone threw a small bag of pebbles into a washing machine. It wasn't very loud, but there no less. When the tech at the shop pulled off the oil canister the oil was filled with gold colored metal flakes-another bad sign. Although after retracing my steps, I actually think, in fact I caught this problem rather late, and feel lucky that my engine didn't seize up. A day before noticing this whine/grind I recall backing the car into a parking space at work and hearing a very loud bang coming from the engine. All seemed fine, so I didn't give it much thought-incredibly stupid of me not to be more concerned then. Anyhow, at the end of that day I drove the car another 17 miles home, and it drove incredibly well, until I started to hear the grind closer to home. Why I didn't put the two together is crazy. I owned a '64 356C that from time to time would make odd sounds from the transmission in reverse, and was an amazing trouble-free car for 15 years. I also owned an old R80/7 BMW motorcycle that used to sound like a tractor going through the gears. So, I guess I just chalked up this sound as German quirkiness, and in no way ever think that it was my engine breaking! Crazy. What happened to German "bullet proof" engineering!? Did I mention I only owned my 996 for 3 months, which just pours salt on the wound!
Anyone interested in buying my car? 30k miles. It still has the new car smell-seriously. Immaculate condition in and out, brand new Michelin PS2's
I guess the fact that I also just had the 60k mile service is of no help since the engine needs a tear down.
#169
Ingiro - As this thread is not intended for discussion I will simply say I that I had a similar experience with my 2004 C4S and a good outcome. See this thread and go talk to a Porsche dealer or contact PCNA directly. Also review the thread on the class action settlement to see if your VIN is in range, you might, at minimum, qualify for 25%
https://rennlist.com/forums/996-foru...-for-pcna.html
#173
I recently purchased a 2003 C2, with 101,000 miles. I had two mechanics inspect it, and there were no problems other than a possible air/oil separator that needed replacement.
But, after reading many forums, I decided to replace the IMSB (LN ceramic bearing replacement) and RMS, as preventative maintenance. Of course, once the engine was out, I quickly compiled a PM list of other stuff to replace (all hoses, belts, water pump, plugs, etc, etc.). So, $8,000 later, I have a car that feels factory new and I don't have to fret over a potential engine implosion due to IMSB.
I guess I have to be a paying member to post pix and an avatar? Maybe I will join after the Mastercard is paid off from the IMSB upgrade.
#176
2004 C2 44k miles. No issues but she goes into the shop tomorrow to replace the IMS. Just bought it and haven't even gotten my hands on it since a test drive Sat. I've been travelling this week and have to travel again next week so I won't get to touch it 'till next Thursday night, and I haven't been able to sleep since Saturday!
#177
2003 996 Cab with 40k miles. I found metal in my oil filter and decided to change it out as a precautionary measure. Once the tranny was out, you could see the IMSB was leaking from the flange. With the bearing was out, it had remarkably little play and appeared relatively intact but the bearing seal appeared to be leaking. I figured it only a matter of time before it failed. While we were In there, also changed out the clutch. The RMS was changed out about 18 months ago and was still in good shape.
#178
This thread is total BS...
#179
Bit harsh there DC! IIRC bearings are not supposed to leak. I certainly wouldn't call that normal and would call that a sign of impending failure.
#180
Re: "$8k!!! it is only 1500-2000 for the IMS, where did the other $6k go?
I had the AOS, LN IMS done for $2k by a very reputable indy."
The $8 k was the total bill for a variety of work I had done, not just the IMSB. New fron brakes & rotors, a tranny mount (there was a small crack), both front control arms & links,plugs, AOS, RMS, power steering hoses, all coolant hoses, air filter, cab filter, all three wiper blades, and some misc. other little parts.
A bit of the "as long as the engine's out I might as well.." syndrome.
