Simple 3-step complete coolant drain (updated w/ refill procedure + water pump tips)
#121
https://www.fcpeuro.com/products/por...hoC4dAQAvD_BwE
#122
Just a car guy
Just to follow up on my last post. My UView showed up yesterday, as promised. Put it to use right away. Used one of the stoppers to seal the reservoir and pressurized the system to push the coolant out of the radiators. Then I used a wet rag to seal around the nozzle to clear the heater core. Amazing how much was still remaining after the engine was drained.
Still have a few things to do before I will be ready to do a water-only flush.
#123
plastic trim remover keeping hose in drain mode
Coolant drain plug "rounding off"
El cheapo gizmo
Ready to apply 8psi
a view from a step back
Car about 2-3 inches higher in the front
I started by raising the car about 2 inches higher in the front and let gravity take out as much as it could......I went with "el cheapo" gadget (38.00 shipped) from Amazon.....the coolant drain plug started rounding off...that thing is super tight (even though sprayed for 2 days with wd-40 before the work started)....going the old way of removing hoses and applying some air pressure to flush...also struggled with the big hose...I used a little plastic gadget used to remove trim...kept it open enough to drain the whole thing under air pressure...will refill with distilled water...run it for a while and flush again.....then remove the heater core and wait for the new one to replace (it is leaking)...that is in another thread...https://rennlist.com/forums/996-foru...the-vents.html
#124
Wow, that's some ugly looking coolant... I think you chose a good time to change it out. Go with the pink stuff this time
85eurocarrera (10-12-2019)
#125
Free of the bad stuff
#126
I'm a Kroil man myself (Kroil Deal). But, PB Blaster and even the old standby of ATF mixed with Acetone work as well.
#127
That's because WD-40 is great for displacing water (WD=Water Displacement) but doesn't do a darn thing as a penetrating oil.
#128
Great idea and very original
Spruden, I just cut a circle out of a 1/8" rubber sheet and cut a hole in the middle of it to accept the air hose. Really no need to be air-tight at all. In fact, being not air-tight gives you some control on how fast you want the coolant to GUSH out
Also, a few PSI is more than enough.
How much air is needed to get the Remaining fluid to flow? Would it be possible with a tire inflator instead of a compressor?
#129
I also used the compressor to power the UVIW 550000 vacuum device to fill the coolant, don’t think that’s possible with a leaf blower or Shop-Vac.
#132
Wow. Yeah that should be enough air but I might try something a little less drastic. This is what happens when your work takes you out of state and you leave your compressor at home. For now, what is it that keeps the radiators from just draining by gravity to the rear? Is there an air lock that needs to be overcome or does the compressor have to provide enough pressure to lift the coolant above a threshold of some sort?
#133
Well, the tire inflator didn't seem to work but I didn't have very good seal either. In addition, I had the back of the car raised a little so front end down. Does the front end need to be up to keep the car horizontal?
#134
A small amount of variation from being level shouldn’t matter much.
#135
I use a small shop vac and got good air flow. It was blowing air out of the disconnected water pump hose. Still did not get a gusher though. Only about three gallons total so far. I think there is something going on, would a stuck thermostat do this?
