Oil Analysis - High aluminum and iron, what does it mean?
i wouldn't worry at all. those average numbers do not reflect different engine design and material used.
as for oil change frequency, i actually think you are changing it fairly frequently at 5k miles or 10k km. i changed mine at 10k mi every two years. engine holds 9-10 qts and this extends the service interval greatly. changing it at 5k miles is even a waste imo. there are those that still subscribe to 3k miles, which is a complete waste of resources.
Quit wasting money on oil analysis, instead use the money to buy more oil. Every 3000 miles or 3 to 4 months. Cheap peace of mind. The oil in all my vehicles always looks new when I check it.
I believe that, in part, the interval debate for our cars is influenced by the IMSB issue and published recommendations. Such as, change the oil at 5,000 mile intervals, run the engine at higher RPM's to promote splash lubrication of the bearing and keep the IMS running concentric. These recommendations have been published on the LNE website, excellence magazine, panamera magazine, and I'm confident published elsewhere as well.
I had the IMSB replaced on the C2 but will still change oil around the 5k mark, but it sure is nice to stop thinking I have to drive her harder than necessary to prevent a problem.
As to oil analysis, makes sense to me and I have them done at each oil change. Again, the IMSB was the promoter for me, consider Jake's "Guardian" as an example. Yet I also like knowing that I have no fuel or moisture present as well.
For the OP - my first oil analysis on my C4S also showed high aluminum and Blackstone commented that as a low mileage engine I might expect the aluminum count to drop as mileage increased. Next change, 5300 miles later, and indeed my aluminum count was closer to the universal average.
The way I see it, the more often I change the oil, the more time I spend under the car checking for problems, finding oil contaminates, leaks, etc. before disaster strikes. I bought my 996 to work on it not drive it into the ground or into an early grave.
Quite a debate going on about intervals. I will try changing it at a lower mileage next year and send another sample to the lab to see. Unfortunatley we get to pay much more for Mobil 1 up north, so each oil change becomes quite expensive, $250-300 depends on where you go. So the oil analysis for $25 is good value to see the condition of the oil before a change.
Captain Obvious
Super User
Super User
I change the oil in my TDI every 35 000km interval and the internals are spotless. This is over twice the factory recomendation. Changing the only like a maniac, doesn't guarantee anything. I never changed the oil before the recomended interval and never had any oil related issues with any of my cars. Something worth thinking about.
To the OP, I took a look at my old reports at roughly the same mileage on my engine. On that particular interval I had ~9000 miles. My Al level was only 1/5 of yours and my iron level was a little less than half of yours.
Thanks, so looks like there might be some abnormal findings. Will do another one next season to see what we find.
