03 Compression check
Was quoted $684 for a compression check during a PPI. Since the car only has 24K miles, the tech suggested I save my money. I've agreed to purchase...mistake or not?
Seems steep.
I've purchased two 996's over 60k miles, both modded and (knock on wood) no engine issues.
However, I obviously can't speak on all of them. Is $684 worth the piece-of-mind and potential of saving you from a jacked engine? Probably.
I've purchased cars without doing a proper PPI / compressor, and been screwed... twice. Figured I'd learn after the first time, I suppose i'm too trusting.
If the car is in stock trim, you're probably fine. You can have them pull the misfire reports from the DME as well.
For a low mileage, naturally aspirated engine I probably wouldn't bother paying for a compression check. If it was a turbocharged engine that someone may or may not have upped the boost on, I wouldn't buy without it.
Ouch...
To give you idea my ppi was $300 and the compression test was $300 and the dealer after doing ppi basically even told me save your money it's a good one no need for compression test 2.5 years later and I guess they were right. I am probably gonna do one at 60k service since plugs will be out.
