03 C4 Drivetrain play
DMF does not have to be bad to clunk a little with a less than stellar shift. Could also be a worn/bad flex disk at the front of the cardin shaft.
Porsche only offers the whole $haft if it is the disk.
Driveshaft flex disc - C4 and Turbo
These folks list the OEM Porsche replacement for $85, KO Performance in Florida. Search the book number.
http://www.koperformance.com/
Part #: 102539005-57
KO Price: $84.61
Shipping: $0.00 - FREE Shipping! - & *Ship Group
Stock Status: In Stock - Ready to Ship!
Book #: 10 2539 005
Description: Driveshaft Flex Disc
Applications: Carrera 4 99 thru 05
Manufacturer: O.E.M.
KO Price: $84.61
Book #: 10 2539 005
AWD brings with it a cardan shaft (runs from the tranny to the front diff) the front diff and the axle half shafts and CV bearings.
The clunking noise could be coming from one of these components.
I remember a while back someone found his Turbo's cardan shaft shot well the bearing at the point the cardan shaft entered the front diff.
Since I own a Turbo which is of course AWD and was a bit worried about how to spot this early (while my car was still under CPO) I talked to some techs about this and they told me they have found very few AWD systems go bad.
Just one or two in the population of cars they've worked on over the years.
The symptom something's wrong is the bad thing is noisy, whatever the bad thing is, all the time.
But a clunking noise might be a new failure mode or just one they never encountered.
Also, as someone else posted the dual mass flywheel might be bad.
But if I recall the car is at the dealer and or will be for a thorough check out and the techs will certainly eliminate any AWD subsystem components along with the dual mass flywheel from the list of suspects. Or they'll id one of the above as the suspect, the source of the noise.
Sincerely,
Macster.
Sincerely,
Macster.
The Service Adviser mentioned that he thought perhaps there might be a problem with the pressure plate.......not providing immediate and clean separation I guess?? The clutch on my car is in fact a lot heavier than the clutch on a 2002 C2 I drove while at the dealership this week. Is the clutch on the C4 supposed to be heavier than on the C2 model?
Also, how difficult is it for the home mechanic to replace the clutch themselves? I do have the garage space and a two post life. Also have worked on and restored many cars over the years, but this is the first time I've ever owned a Porsche and NEVER worked on one.
I'll bring the thoughts of the cardan shaft and bearing to the attention of the dealership.
Once again, thanks for all the help and good advice!
Best
Les.
Just as easy as most other cars. Do a search for IMS replacement threads.
You need to support the engine as the trans mount acts as one end of the engine mounts.
Here is one:
https://rennlist.com/forums/996-foru...s-bearing.html
The clutch should be as easy as C2. Some reasons for heavy clutch are:
Worn disk changes the geometry of the clutch fork assy increasing force required to press clutch in.
Broken/removed helper spring (clutch pedal shaft - small can above your foot)
Long story about clutch helper spring
https://rennlist.com/forums/996-foru...matically.html
Here is one:
Here is one:
Here is one:
Looks like removing the bits and pieces to replace the clutch isn't that bad at all, but I agree, bit of a nightmare without some way of getting the car well off the ground. Oh boy, how that brings back memories of scrambling about under cars using only ramps when chaging out clutches......back in the day when I just about had a pot to pee in, but not much more.
Thanks for the help and guidance.
Les.
The dealer has dropped the belly pans and checked out all the apparent components without finding any play. This is good and bad news, imo. Good in that there's nothing apparently wrong with those components, bad in that perhaps the problem, if there is one, lies on the interior.
Best
Les.
Best
Les.
My WAG (based on what I've read here by those that have done it themselves is that the job is not that hard a job, but you want to be sure you have the best DIY and have the proper equipment.
For instance when my Turbo's 6-speed transmission was being replaced the tech supported the engine with a special engine stand while the car was on the lift and at a comfortable working height too.
The support wants to be very reliable and secure. At the dealer there's no risk but at home, have an excited dog run into the support and knock it out from under the car....there could be expensive repercussions.
Oh, I took my Turbo out the other day and after the drive train was fully up to operating temp I managed to get a bit of a clunk (not that bad though, thank goodness) by in 1st or 2nd accelerating the car up to around 2K and then quickly releasing the gas pedal, then reasonably quickly again pressing down on the pedal.
The knock is I suspect arises from the clearances that are present. I never drive my car this way though on purpose, save this time of course, but once in a great while while I just get just sloppy with the clutch/pedal and hear a faint clunk from I suspect the drive train gear lash.
As I was driving the car before and during and after this I was thinking to myself that I strive -- it comes almost second nature to me I guess for I do not think I consciously think about this constantly while driving -- to be gentle/smooth with the car and its controls.
Sincerely,
Macster.
Sincerely,
Macster.
Since conversing with you guys I've been changing gear further up the range.....3k and above.....99% no clunks when doing this and I think the remaining 1% is likely due to my being overly sensitised to it and perhaps hearing things that under any other circumstances, I would not.
Once again people, I sincerely do appreciate your help and indulgence of this newbie.
Best Regards
Les.
One other thing that can give a clunk is a worn/deteriorating trans mount. You would get that clunk every time you let up on the gas and stepped on it again. Not just on gear changes.
Thanks for the input!
Les.
