996 Forum 1999-2005
Clock LED light is out on my 2000 996, easy fix?
Old 05-26-2012, 02:46 PM
GTRSR
GTRSR's Avatar
Check suncoast or pelican parts. I used aftermarket LEDs (ebay) with mixed results (bulbs are easier to install and look more factory "original"). I believe the LCD bulbs are 1.5watts so:
Part #: * 999-631-303-90-M97
Under $2 online.
Old 05-26-2012, 07:22 PM
EastBay
EastBay's Avatar
Old 05-27-2012, 09:17 PM
carcster88
carcster88's Avatar
Originally Posted by EastBay
Thanks very much EastBay. Funny thing is it started to work again today. I think the bulb might be lose.
Old 05-27-2012, 11:03 PM
ttreat
ttreat's Avatar
Unless your instrument cluster is significantly different from a '01 cluster, the clock/oil level area is an LCD panel attached with a ribbon. There is no light bulb. The LCD is powered through the ribbon. Chances are that the ribbon connection is going bad. Here is a picture (sorry it's not the best quality) of the clock panel that I removed from the instrument cluster that I used as a donor for my center panel.
Old 07-07-2012, 05:49 PM
machbx
machbx's Avatar
Originally Posted by carcster88
Went to the Porsche dealer today and they think there is a bulb behind there. They want an hours labor to remove the cluster. Right now looking for a DIY on cluster removal. If it is just a bulb...I should be able to change that. Any link to a DIY for gauge cluster removal on a 996?
This is my next project - for tomorrow am - has anyone seen red led's? and if so is it possible to do the climate control and the CDR 220 radio?
Old 07-07-2012, 09:13 PM
carcster88
carcster88's Avatar
For some reason it started working again a few days later and has been working since. Go figure....
Old 07-05-2014, 04:37 PM
NIKAS
NIKAS's Avatar
The bulb behind LCD speedo/temp screen in center cluster expired in mine; does anyone know correct bulb to order to replace? Green, black, or beige? TIA!
Old 07-05-2014, 05:02 PM
particlewave
particlewave's Avatar
Blue! I think I have a bag of theses somewhere left over from LED conversions...
Old 07-05-2014, 05:16 PM
particlewave
Ok, I just checked and the LCD bulbs are beige, but I've used black in them and the intensity seems identical.
Anyone that needs cluster bulbs, PM me for freebies.
Old 05-29-2022, 01:20 AM
scottmo
scottmo's Avatar
yes, same issue for my 2001 996.
Rarely, does it work.
Did you find any fixes?
Quick Reply: Clock LED light is out on my 2000 996, easy fix?
