Daytime Running Light Problem with LED Tail lights - Solved
I just installed smoked LED tail lights on my 2000 996. No hyper flashing but only the passenger side of the tail light is lit when in day light running mode (I live in Canada). When I manually turn on the headlights, both sides are lit and everything else works.
Can anyone who has installed load resisters give me some guidance on how to install them? Do you just splice them in to one of the wires on each side?
I've never worked with resisters and could use some help.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
check your fuse a6 and a7. I am in the process of installing those too and lots of problems. i gave up on trying to hook up the side markers in the back as it kept blowing a fuse. now my problem is that the rear fog light only work on the driver side. there is no fuse for left/right fog lights so not sure what is wrong, i am going to connect back the original lights and see if they work as I never checked.
are you referring to side markers?
Since I installed the LED tail lights, the driver's side tail light only turns on when the headlight switch is turned on while the passenger side tail light is on al the time. This of course looks odd unless the headlight switch is turned on.
I purchased 2 - 8 ohm 25w resisters today and will install them tonight on the tail light/brake light wires. I'll post my results.
what???? this does not make any sense... what is a rationale for it? I guess now I know why I only have one orange bulb left. I thought I lost the other one...
The "Things you didn't know" thread has lots of good info.
Thanks in advance.
Thanks in advance.
Great news. Photos?
How did you determine the proper ohm / watt resistor? I have the same problem as I just installed some LED tail lights tonight. Strange that the passenger side works without issue! It also knocked out my front Driver's side DRL (I have LED there too).
Why did you put the resistor on BOTH the brown and wires and just not one of the two?
Thank you for posting this thread - very helpful!
The resistance wattage was suggested by my LED tail light supplier. I'm not an electrician, but the resister is supposed to simulate the load created by an normal bulb, so I think it needs to cross both wires. I also referenced similar posts on their installation.
Just wanted to thank you for the response... I figured out that I had blown a fuse when installing the tail lights. I think I may have had the small light plug reversed, but not sure. For me, even though I have LED head lights, tail lights, and LED strips in both 3rd brake bars, I haven't needed to install any resistance elements. Not sure if this is rare luck, or if I'm missing something...
I recently ordered the Spyder LED tail lights from Amazon ( $299 )
Very happy with the look.
They have built in resistors and are plug and play - no hyperflashing etc.
The small sidemarker lights are indeed color coded - the white and red marked ends have to be inserted correctly. If you do this correctly - no problem.
If not - a blown fuse plus hyperflashing.
(I blew two before figuring this out)
If they included a couple of lines of instruction or a simple diagram they would have many happy customers!!!
I think the quality of this product is excellent - as good as OEM.
Highly recommended!
Highly recommended!
