correct 996 transmission bell housing bolt
all...my friend has a 1999 996 and needs one of the 10mm bolts w/tourque head that bolts the transmission to engine...here is the socket that is used for this bolt showing the triple square socket head type:
http://www.pelicanparts.com/cgi-bin/...39%2D%30%34%29
**does anyone have a part# or source to buy just one of these??
thanks in advance
thanks in advance
thanks in advance
thanks in advance
thanks...i PM'd you
is it a 12 point torque head or basic allen head which i belive is 6 point?
If you aren't going to do the triple square bolt and use my suggestion, buy one of these too, it's 50mm instead of 48mm for the above part. 900-067-123-09. Buy that one plus 900-067-229-01. One will work.
But I can't remember which I used. One of them was exactly the same except without the XZN head.
is it possible to find the original with the 12 point XZN head which would match the others on the bell housing?
I've been told that the bolts differ based on model years and factory where the hardware was made.
I'm not sure if you would get the XZN head if you ordered one new today, but you could try.
Is there a reason why you are looking for triple square?
i think thats the style on his transmission but if the 6 point hex head style is the only one available i'll buy one of those....appreciate the help
Hey grovezilla,
When I did my clutch job I decided to replace a couple of the bolts. Because of the time constraint, I went over to the Bellevue Porsche dealer where they only wanted ~4 bucks for each one. They also had them in stock.
Not a bad deal if you need them right away.
thanks...took "logray's" advise and i ordered the hex head style in 50 and 48mm lengths and they should be here by the end of the week... i'd like to locate the 12 point head if possible.
