996 Forum 1999-2005
Need help to identify this set of PSS9 - got them...
Old 09-22-2011, 06:13 PM
LC MotorSports
Former Vendor
LC MotorSports's Avatar
Old 09-22-2011, 09:42 PM
Dharn55
Dharn55's Avatar
The PSS10's I have came with a lifetime guaranty. Maybe Bilstein will rebuild them for free.
Attached are the specs for the PSS10's for a Turbo, for a C4 and the PSS9 specs for a C4. Unfortunately I don't have them for a C2. I found these on-line in 2010 but when I go to the site now I can find them again or the C2 specs. The specs list the part number for each component and may help you identify the set you have. Wish I had gotten them for the C2 when I got these.
File Type: pdf
Old 09-22-2011, 09:51 PM
philooo
philooo's Avatar
I decided to buy them, so we'll know soon if they fit
now it is time for me to decide if I want to do at the same time some more upgrade to get more negative camber :
- camber plate with monoball (gt3 or tarett or rennline)
- lower control arm (gt3 or gmg)
- monoball bushing
I am doing the upgrade to have the car a little bit more track friendly so...
Hoping that I will not be getting the dreaded PSS grinding noise that some other have experienced. Anyways after two suspension install within a year it shoudl be easy to take them in and out..hopefully
Old 09-22-2011, 10:00 PM
LC MotorSports
Former Vendor
If you start making the other upgrades give me a call. We carry a Full line of TRG components, OEM parts, PMNA parts as well several of our own suspension parts. While offering discounted pricing to all Rennlist members.
Old 09-30-2011, 07:46 PM
philooo
philooo's Avatar
ok I got the set
Today I inspected the part and while I was able to compress the rear, with a lot of force I have to say, I could not make the front shock compress one millimeter even with my considerable weight
Is that normal ?
Because when I installed the RoW030 I was able to compress the rear with one hand and the front with both hands. mucchhhhh softer
Are the pss9 that much stiffer ? As it seems they have never been installed, I want to check as much as possible that they are at least functional
Old 09-30-2011, 09:32 PM
LC MotorSports
Former Vendor
Congrats on the new legs for the ride. The shocks will be much stiffer then the RoW030 units.
Old 09-30-2011, 09:35 PM
philooo
philooo's Avatar
BTW if anyone has the PSS9 manual, I am interested
ok, I am on my way to start the rennlist search for any PSS9 install documents...
Old 10-01-2011, 10:19 AM
Hal
Hal's Avatar
Just had a used set of PSS9's installed on my '99 along with all new Elephant Racing bushings. Stunning difference. You will love them when you are finished.
Old 10-01-2011, 10:41 AM
chsu74
chsu74's Avatar
Let me look around but everything is in boxes. If I find it, I will scan and email it to you.
Old 10-01-2011, 11:20 AM
Sneaky Pete
Sneaky Pete's Avatar
Found this online at http://www.truckspring.com/suspensio.../bilstein.aspx ...look at the Product Overview tab and you can download the instructions. They are the PSS10 but the install should be the same.
Old 10-01-2011, 11:27 AM
philooo
philooo's Avatar
Thanks pete
Old 10-05-2011, 03:17 PM
chsu74
chsu74's Avatar
here you go
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 10-05-2011, 08:07 PM
philooo
philooo's Avatar
thanks do much Chao ! that is very much appreciated !!
Old 10-08-2011, 12:37 AM
perryinva
perryinva's Avatar
Be careful to notice exactly what parts are re-used from your old struts. It is MUCH clearer on the PSS10 vs the PSS9 manual (exact same parts re-used). I went ahead and got new upper strut mounts (I'll find the part numbers) and I had a post around somewhere of the part number and small cost of additional blue washers which prevent windup and spring back noise. You should be able to compress all of them, BTW, though it takes some effort.
Old 03-14-2013, 07:52 PM
edugoy
edugoy's Avatar
Unhappy PSS9 TVU report
Has anyone the TUV report for this kit?
I have the installation instructions (11 pages) that came in the box, but there is no TUV for homologation.
PSS9 for the 996C2 from 2002. The front shocks are VM3-5252 and the rear shocks are BM5-6803. The Bilstein kit part# is F4-GM5-8846-H0
I would be very grateful if you could send me this TUV report in PDF or so.
PD. I have found PSS10 (GM5-D534) installation instructions pdf and there is TUV homologation in it, but not in mine (GM5-8846)... please help!
Quick Reply: Need help to identify this set of PSS9 - got them...
