*oil can image* - "Failed Indicator"
#31
To replace the entire sender with the engine in car, it's easiest to remove the bumper, passenger side heat shield and muffler. From there it is dead easy to get a stubby wrench up to where it sits atop the camshaft cover.
It simply screws into the cam cover on 4-6 cylinder head. New ones come with a new washer. There are two connections for wires for the instrument cluster. Almost as easy as installing a light bulb.
If you don't want to remove the bumper or heat shield, you can just remove the muffler. From there you can probably get to it using a crows foot on a long extension.
The oil pressure sender is in this picture, in the lower right hand side, the round cylindrical thing with two wires poking out the top.
#32
The part came in. Olympus didn't have any crows foot sets and NAPA only had a set where the ends curve around and would have to be sawed off in order to slide in straight.
So I bought at 19mm wrench.
The only questions remaining now are:
Do I need to be cognizant of torque settings? The workshop manuals downloaded from the url in this thread do not address "oil pressure sender" at all.
Do I need to use thread sealant and if so, which kind?
#33
I've driven some deep rains and found letting things dry out helps extrememly. A toyota I had loved to conk out the a/c going though 6-12" water. I'd reset till dry and see what happens. Cars and the fancy sensors don't go good with shorts and sensors with water in them.
#34
I hand tightened mine until it was good and snug. At that point it was oriented exactly the same as the old one (meaning the wires were in the correct positions). I didn't want to risk another complete 360 turn as it would have certainly damaged the threads.
I believe the threads might be pre-sealed, and if they aren't the new crush washer that is on there should do the trick. No leaks on mine...
