Help!! 2003 996 c4 tiptronic convert to 6 speed throttle body problem
Hi experts,
Please help me out here if you can, due to from where I come from, 6 speed 996 almost have no existence so I decided to convert my 996 c4 tip to manual 6 speed. I have completed the swapping but something unexpected came up, seems like the computer is giving the electronic throttle body limitations due to can not detect the tip trans, the throttle would not open up the the correct position according to the gas paddle, not until it hits 4500 rpm where the limitation will be off and the car flies. I need your expert advise on how do I resolve this problem, thank you in advance.
Any Help will be helpful, please help out
Hi,
Anyone has any idea on this issue? I from researching the board, I have seen that many people said the manual and tip ECU are the same, I just need to reprogram?? But I also found people saying that I need to get a new ECU, so I really dunno how to resolve this, please help out.
The ECU is confused. It's looking for a speed signal from the input shaft of the transmission which the 6 speed doesn't have. Different pin allocation and the ECU map is different, but it's possible to make it work.
HI Axeman
You mean I can make it work if i do the pin allocation and remap of my ecu?
Do you know how should I do the pin allocation? or swap to manual harness will make it work?
As for the remap, I can use the auto ECU with a remap maybe from GIAC to resolve it?
Thank you in advance!
Basic Site Sponsor
Basic Site Sponsor
Get yourself a 996 Factory Workshop Manual, in Diagnostic -section is a chart of Motronic pinouts.
The chart also has been floating around as downloadable file in 6bling's 996 turbo area.
Basically, after correct pins in correct plugs the rest should be reprogramming. GIAC or Softronic
Do you already have manual car's dashboard? Do you want one? I have an extra...
Pete
Power. Lots is good, more is better, too much is just right...
'87 951, RIP
'00 996 C2 L92U AQ / IXAA IXRB IX54 M96/7.xx G96/7.88 M030 M375 M376 M436 M476 M601 M983 ... + 991 GT3 brakes, 997 GT3 sway bars, fully monoball'd suspension, Bilstein Cup Car coilovers, do88 Big Pack ICs. 10 & 12 x 19" BBS CH-R wheels with 265/30 & 325 /30 -19 MPSC2s.
Pete
'87 951, RIP
I have see 3 connection for Tiptronic on ECU:
1.) CAN HIGH tiptronic
2.) CAN LOW tiptronic
3.) RELEASE P\N
Do I unplug these? or I need to find out how the manual computer's pin layout and pin it accodingly?
3.) RELEASE P\N
Hi there I'm little late on this forum but I'm in the middle of the conversion could you please let me know what you have done with the wiring to make it work ?
