996 Forum 1999-2005
*UPDATE: NOT IMS FAILURE!! ** Imminent IMS Failure? HELP! (With Video)
Old 08-05-2011, 08:11 PM
alan111
alan111's Avatar
Default *UPDATE: NOT IMS FAILURE!! ** Imminent IMS Failure? HELP! (With Video)
Hi Everyone,
Drove my car last night about 10 miles, drove it both softly and hard. At around 6:00pm today I went to start it up and after about 15 seconds, I hear a rattling from the engine. The first thing I thought of was to snap a quick video and to turn it off. Please check it out and let me know your thoughts!
Video was taken at the rear left side.
Hoping for the best,
Alan
Old 08-05-2011, 08:18 PM
wyovino
wyovino's Avatar
I can't tell you what the sound is, but I HIGHLY recommend that you don't start it again until you know.
Old 08-05-2011, 08:47 PM
alan111
alan111's Avatar
Definintely, i Know.
Anyone else??
Old 08-05-2011, 08:56 PM
jeneric996
jeneric996's Avatar
I cannot hear it well, but it doesn't sound normal. If it sounds like a loose nut moving around, then it is most likely the IMS bearing. Mine blew at 23,000 miles. It first made the loose nut noise in the crankcase and when I shut it down, it leaked a few quarts of oil. It was the IMS in my case.
Old 08-05-2011, 09:15 PM
GaryAZ
GaryAZ's Avatar
When one of my stock mufflers died it sounded like a crushed beer can rattling around in there. Your deal doesn't really sound like that but fyi. hoping for the best.
Old 08-05-2011, 09:16 PM
pesuazo
pesuazo's Avatar
I would first remove the mufflers and shake them.....the mufllers are known to break internally and make a rattling sound......do this before you start the car again.....
Old 08-05-2011, 09:19 PM
GaryAZ
GaryAZ's Avatar
or tap them with a rubber mallet a few times first and see if you get any rattle.
Old 08-06-2011, 02:45 AM
996 Kuwait
996 Kuwait's Avatar
I just replace my mufflers 5 days ago because both of them died....and sorry to tell you but wasn´t that sound at all!!!!!
Sorry and I hope U the best
Old 08-06-2011, 10:00 AM
mjb2448
mjb2448's Avatar
Hopefully that quick action prob saved your motor, and pretty lucky you were in your garage. When you made the purchase a month ago did you do a PPI ?
An '02 with 52K on the clock seems like it was driven well for a cab in your area, did the previous owner store during winter ? I see that you're on the list for the IMS Guardian, and drove your car knowing the worst thing for the IMS is to sit and veg in the garage.....well your situation awareness and luck may take some of the sting out. Best Wishes.
Old 08-06-2011, 12:17 PM
philooo
philooo's Avatar
I assume that his only way of knowing will be to remove the transmission and do the IMS upgrade, right ?
Old 08-06-2011, 01:14 PM
rpm's S2
rpm's S2's Avatar
Good luck!
Old 08-06-2011, 02:02 PM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,293 Likes on 903 Posts
He emailed me this last night.. It DOES sound like the death rattle.. Hopefully running it long enough for the sound bite didn't do too much collateral damage.. SECONDS is all that separate catastrophe from salvation.
DO NOT START THIS ENGINE AGAIN FOR ANY REASON until it is expertly diagnosed!!
Old 08-06-2011, 03:39 PM
Byprodriver
Byprodriver's Avatar
Cut open the oil filter to check for metal/debris!
Old 08-06-2011, 10:42 PM
alan111
alan111's Avatar
Thanks everyone for the input. I have not restarted the engine since that video, and am hoping for the best. So far there is no oil spill under my car, no oil leak at all, so it looks like I may be in the clear for a just an IMS repair.
Anyone have any recommendations for LNE bearing retrofit in either the NYC, NY area or Monmouth, NJ area?
Old 08-06-2011, 11:01 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
ROCS auto in belleville, NJ, they have done many. Good shop, they did mine.
Quick Reply: *UPDATE: NOT IMS FAILURE!! ** Imminent IMS Failure? HELP! (With Video)
