996 Forum 1999-2005
I have an oil leak, what is leaking? PICS
Old 04-07-2011, 12:00 PM
white99c2
white99c2's Avatar
Default I have an oil leak, what is leaking? PICS
Drivers side next to the rear tire.
Uploaded with ImageShack.us
Old 04-07-2011, 12:15 PM
ivangene
Parts Specialist
ivangene's Avatar
sure its oil? might be coolant
suspect: spark plug tube or expantion tank depending on what the fluid is ... could also be the bellow on the AOS, the cam solenoid seal, or other
Old 04-07-2011, 12:17 PM
pat056
pat056's Avatar
Are you sure it's oil? Can you take a pic of the engine? Could be coolant from expansion tank, could be oil from AOS, could be overfilled oil, could be hydrolic fluid...
Old 04-07-2011, 12:18 PM
pat056
pat056's Avatar
Musta replied at the same time.
Old 04-07-2011, 12:22 PM
white99c2
white99c2's Avatar
Updated the last pic to show you where its leaking and yes it is 100% Mobile 1 not coolant. The tank was recently changed. Wiped it off and there was GOLD Mobile 1 on a paper towel.
Old 04-07-2011, 12:57 PM
ivangene
Parts Specialist
ivangene's Avatar
wait, what year car? (you may not have spark plug tubes)
Old 04-07-2011, 01:03 PM
white99c2
white99c2's Avatar
Its a '99 C2
Old 04-07-2011, 01:06 PM
Sneaky Pete
Sneaky Pete's Avatar
You have tubes. Mine had the same issue a few years back. And it was on the left side like yours.
Old 04-07-2011, 02:22 PM
ivangene
Parts Specialist
ivangene's Avatar
so spark plug tubes right Pete?
Old 04-07-2011, 03:07 PM
fpb111
fpb111's Avatar
It is a DIY Do a search on "spark plug tube replace" you will get many threads with a number of successful methods.
https://rennlist.com/forums/996-foru...acement-2.html
https://rennlist.com/forums/996-foru...a-1999-c2.html
ETC...
Old 04-07-2011, 03:18 PM
CWhaley
CWhaley's Avatar
As usual I am late to the game....
Old 04-07-2011, 03:37 PM
ivangene
Parts Specialist
ivangene's Avatar
well did you at least bring beer?
Old 04-07-2011, 03:46 PM
CWhaley
CWhaley's Avatar
Duh! All I brought was a bottle of Glenfiddich.
Old 04-07-2011, 05:05 PM
Dharn55
Dharn55's Avatar
Could also be the cap and seal around the cam advance mechanism, very common leak.
Old 04-07-2011, 05:58 PM
Sneaky Pete
Yup, but Doug has a good point.
Quick Reply: I have an oil leak, what is leaking? PICS
