Lightweight street or street/track 996 builds out there?
#77
You can also go the other way with this. Take a full blown race car and add the weight back for the creature comforts you want to retain. My 04 996 GT3 RSR weighs in at 2370 pounds with no fuel. It has a heavier than EO fuel cell and pumps, brake parts, heavier large wheels and tires and it has a heavy electric power steering pump in the front trunk along with a full cage etc. Obviously, it's stripped otherwise. it may have been built with thin gauge steel also but I don't think so because many teams build competitive race cars from the street GT3 cars and they claim there is no difference in weight (but I've never confirmed this).
#78
FWIW.... My latest 996 is a 03' X51 sunroof delete(steel skin) and weighs 2,500 empty, about 75lb. more than my 99' 996. Nothing much different between the 2 cars except the 03' has a chromoly cage vs. the DOM cage in the 99' car. The 99's were just lighter to begin with....
#79
I have the documents that PORSCHE put out that goes over the improvements. It was a big help for the street cars to feel more solid, be quieter, and handle better.
That extra rigid chassis came at the expense of a little more weight. In reality, if you did your cage correctly then that factory extra steel won't help the chassis any because the cage will be doing a much more serious job of adding rigidness.
Let me know if you really want to know more JR., if so I will try to dig up the documents from PORSCHE that explain it in greater detail.
Btw, as I remember it your 99 had a 1.5" and pretty bare bones cage, correct ?
I'm guessing this 2003 car handles much differently than the 99, can you feel the difference ? I know there are numerous other changes as well so it might be hard to tell.
#80
I've always been under the impression that even with a full cage tied into the suspension pick ups, that the chassis inherent rigidity is still important. Basically even with a well built cage it's not good to shed weight at the expense of weakening the chassis.
#81
True, but a well built cage will do more than PORSCHE did with their additional metal.
#83
Interesting tips in this (old) thread!
You might also want to be aware of this build thread as it contains some interesting bits including lots of details and pictures of a CF roof conversion, a custom built steering rack and much more:
The 996 CLR (after his avatar CarreraLightweightRacing)
Intro to the build: https://www.pistonheads.com/gassing/...f=48&t=1604071
Build Thread: http://911uk.com/viewtopic.php?t=106137
